Can't build blend
Hello!
I am trying to build a blend. In most cases it works without errors. But there was an error which I cannot solve in any way. I am building two lists of points:
List 1:
▶ [0] {(63.188185135, 316.762797009, 10.575185926)}
▶ [1] {(63.546271620, 317.149454112, 10.542377527)}
▶ [2] {(63.903538667, 317.535226397, 10.509569129)}
▶ [3] {(64.260949278, 317.921153700, 10.476760730)}
▶ [4] {(64.709897356, 318.405921963, 10.443952331)}
▶ [5] {(65.065708378, 318.790122050, 10.411143932)}
▶ [6] {(65.420020981, 319.172704165, 10.378335533)}
▶ [7] {(65.773766315, 319.554673750, 10.345527134)}
▶ [8] {(66.126991208, 319.936081370, 10.312718735)}
▶ [9] {(66.479742220, 320.316977298, 10.279910336)}
▶ [10] {(66.832065660, 320.697411541, 10.247101937)}
▶ [11] {(67.184007619, 321.077433865, 10.214293538)}
▶ [12] {(67.535613986, 321.457093822, 10.181485139)}
▶ [13] {(67.887674002, 321.837243622, 10.148676740)}
▶ [14] {(68.331065166, 322.316011602, 10.115868341)}
▶ [15] {(68.682627158, 322.695623643, 10.083059942)}
▶ [16] {(69.033313585, 323.074290260, 10.050251543)}
▶ [17] {(69.383903828, 323.452853020, 10.017443144)}
▶ [18] {(69.734443081, 323.831360720, 9.984634745)}
▶ [19] {(70.084976510, 324.209862131, 9.951826346)}
▶ [20] {(70.435549276, 324.588406019, 9.919017947)}
▶ [21] {(70.786206563, 324.967041171, 9.886209548)}
▶ [22] {(71.136993598, 325.345816424, 9.853401150)}
▶ [23] {(71.489050283, 325.725962628, 9.820592751)}
▶ [24] {(71.977057821, 326.252906785, 9.787784352)}
▶ [25] {(72.329736555, 326.633724669, 9.754975953)}
▶ [26] {(72.681632457, 327.013697262, 9.722167554)}
▶ [27] {(73.033903886, 327.394075343, 9.689359155)}
▶ [28] {(73.386596903, 327.774908650, 9.656550756)}
▶ [29] {(73.739757790, 328.156247156, 9.623742357)}
▶ [30] {(74.093433070, 328.538141099, 9.590933958)}
▶ [31] {(74.447669538, 328.920641004, 9.558125559)}
▶ [32] {(74.802514280, 329.303797714, 9.525317160)}
▶ [33] {(75.159357820, 329.689112702, 9.492508761)}
▶ [34] {(75.654375213, 330.223626009, 9.459700362)}
▶ [35] {(76.013038140, 330.610905547, 9.426891963)}
▶ [36] {(76.371124625, 330.997562649, 9.394083564)}
List2:
▶ [0] {(59.810457068, 320.991798868, 10.575185926)}
▶ [1] {(60.138728956, 321.346262560, 10.542377527)}
▶ [2] {(60.466249635, 321.699915105, 10.509569129)}
▶ [3] {(60.791996924, 322.051652768, 10.476760730)}
▶ [4] {(61.207373088, 322.500170517, 10.443952331)}
▶ [5] {(61.531656072, 322.850327041, 10.411143932)}
▶ [6] {(61.856468296, 323.201055033, 10.378335533)}
▶ [7] {(62.180760482, 323.551221493, 10.345527134)}
▶ [8] {(62.504575560, 323.900872779, 10.312718735)}
▶ [9] {(62.827956211, 324.250054977, 10.279910336)}
▶ [10] {(63.150944892, 324.598813930, 10.247101937)}
▶ [11] {(63.473583853, 324.947195261, 10.214293538)}
▶ [12] {(63.795915165, 325.295244395, 10.181485139)}
▶ [13] {(64.116770530, 325.641699822, 10.148676740)}
▶ [14] {(64.527027545, 326.084689981, 10.115868341)}
▶ [15] {(64.847427011, 326.430653133, 10.083059942)}
▶ [16] {(65.168914976, 326.777791634, 10.050251543)}
▶ [17] {(65.490314768, 327.124834925, 10.017443144)}
▶ [18] {(65.811667814, 327.471827741, 9.984634745)}
▶ [19] {(66.133015520, 327.818814792, 9.951826346)}
▶ [20] {(66.454399289, 328.165840782, 9.919017947)}
▶ [21] {(66.775860542, 328.512950438, 9.886209548)}
▶ [22] {(67.097440740, 328.860188530, 9.853401150)}
▶ [23] {(67.417384384, 329.205659493, 9.820592751)}
▶ [24] {(67.870362172, 329.694778983, 9.787784352)}
▶ [25] {(68.190874868, 330.040864401, 9.754975953)}
▶ [26] {(68.513471608, 330.389200141, 9.722167554)}
▶ [27] {(68.836412607, 330.737907608, 9.689359155)}
▶ [28] {(69.159740093, 331.087032399, 9.656550756)}
▶ [29] {(69.483496493, 331.436620325, 9.623742357)}
▶ [30] {(69.807724459, 331.786717442, 9.590933958)}
▶ [31] {(70.132466887, 332.137370068, 9.558125559)}
▶ [32] {(70.457766942, 332.488624813, 9.525317160)}
▶ [33] {(70.782071719, 332.838804870, 9.492508761)}
▶ [34] {(71.241532347, 333.334924447, 9.459700362)}
▶ [35] {(71.567501521, 333.686901697, 9.426891963)}
▶ [36] {(71.895773409, 334.041365388, 9.394083564)}
Then I connect all the points with lines. I also add a vertical line from the zero point up and from the last point up. And the third line that connects them.
As a result I get an error message: "unexpected internal error : code 1"
I checked the data for parallelism. It seems that there are no problems. I started trying different options and found that if I remove the point at number 1 in both lists, then everything works fine and looks like this:
Can someone suggest what is the problem?
