Can SketchEditScope be used to change sketch-based elements, e.g. floors?
zhuliyi0
zhuliyi0
SketchEditScope is a new API feature in 2022, and I was expecting it to be able to do editing just like with the UI: enter edit mode, make change to sketch curves, then finish. However I cannot find any documentation of how to do it. I found the Sketch element retrieved by .SketchId has only read-only properties.
If SketchEditScope cannot be used to freely make change, then it is not too different from the existing limited workrounds:
https://forums.autodesk.com/t5/revit-api-forum/editing-a-floor-profile-get-void-in-floor/m-p/7171573
Can anyone clarify what sketch API really can do?
jeremy_tammik
Afaict, it should do exactly what you are asking for. What's New gives a brief description:
https://thebuildingcoder.typepad.com/blog/2021/04/whats-new-in-the-revit-2022-api.html#4.2.1.6
I do not have an example at hand. I've asked the devteam for one for you.
jeremy_tammik
Here is a sample macro that was uploaded to the Revit Preview forum:
 * Sample - Edit Floor Sketch.cs
 * Created by SharpDevelop.
 * User: t_matva
 * Date: 11/17/2020
 * Time: 11:18 AM
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace Sample
    [Autodesk.Revit.Attributes.Transaction( Autodesk.Revit.Attributes.TransactionMode.Manual )]
    [Autodesk.Revit.DB.Macros.AddInId( "994A64E6-839B-4C1F-B473-1E7C614A5455" )]
    public partial class ThisDocument
      private void Module_Startup( object sender, EventArgs e )
      private void Module_Shutdown( object sender, EventArgs e )
      #region Revit Macros generated code
      private void InternalStartup()
        this.Startup += new System.EventHandler( Module_Startup );
        this.Shutdown += new System.EventHandler( Module_Shutdown );
      #endregion
        public void CreateFloor()
        Curve left = Line.CreateBound( new XYZ( 0, 0, 0 ), new XYZ( 0, 100, 0 ) );
        Curve upper = Line.CreateBound( new XYZ( 0, 100, 0 ), new XYZ( 100, 100, 0 ) );
        Curve right = Line.CreateBound( new XYZ( 100, 100, 0 ), new XYZ( 100, 0, 0 ) );
        Curve lower = Line.CreateBound( new XYZ( 100, 0, 0 ), new XYZ( 0, 0, 0 ) );
            CurveLoop floorProfile = new CurveLoop();
        floorProfile.Append( left );
        floorProfile.Append( upper );
        floorProfile.Append( right );
        floorProfile.Append( lower );
        ElementId levelId = Level.GetNearestLevelId( Document, 0.0 );
        using( Transaction transaction = new Transaction( Document ) )
          transaction.Start( "Create floor" );
          ElementId floorTypeId = Floor.GetDefaultFloorType( Document, false );
          Floor floor = Floor.Create( Document, new List<CurveLoop>() { floorProfile }, floorTypeId, levelId );
          transaction.Commit();
      // Find a line in a sketch, delete it and create an arc in its place.
      public void ReplaceBoundaryLine()
        FilteredElementCollector floorCollector = new FilteredElementCollector( Document )
           .WhereElementIsNotElementType()
           .OfCategory( BuiltInCategory.OST_Floors ).OfClass( typeof( Floor ) );
            Floor floor = floorCollector.FirstOrDefault() as Floor;
        if( floor == null )
          TaskDialog.Show( "Error", "Document does not contain a floor." );
          return;
        Sketch sketch = Document.GetElement( floor.SketchId ) as Sketch;
        Line line = null;
        foreach( CurveArray curveArray in sketch.Profile )
          foreach( Curve curve in curveArray )
            line = curve as Line;
            if( line != null )
              break;
          if( line != null )
            break;
        if( line == null )
          TaskDialog.Show( "Error", "Sketch does not contain a straight line." );
          return;
        // Start a sketch edit scope
        SketchEditScope sketchEditScope = new SketchEditScope( Document, "Replace line with an arc" );
        sketchEditScope.Start( sketch.Id );
        using( Transaction transaction = new Transaction( Document, "Modify sketch" ) )
          transaction.Start();
          // Create arc
          XYZ normal = line.Direction.CrossProduct( XYZ.BasisZ ).Normalize().Negate();
          XYZ middle = line.GetEndPoint( 0 ).Add( line.Direction.Multiply( line.Length / 2 ) );
          Curve arc = Arc.Create( line.GetEndPoint( 0 ), line.GetEndPoint( 1 ), middle.Add( normal.Multiply( 20 ) ) );
          // Remove element referenced by the found line.
          Document.Delete( line.Reference.ElementId );
          // Model curve creation automatically puts the curve into the sketch, if sketch edit scope is running.
          Document.Create.NewModelCurve( arc, sketch.SketchPlane );
        sketchEditScope.Commit( new FailuresPreprocessor() );
      /// <summary>
      /// Add new profile to the sketch.
      /// </summary>
      public void MakeHole()
        if( floor == null )
          return;
        // Create a circle inside the floor
        SketchEditScope sketchEditScope = new SketchEditScope( Document, "Add profile to the sketch" );
        using( Transaction transaction = new Transaction( Document, "Make a hole" ) )
          // Create and add an ellipse
          Curve circle = Ellipse.CreateCurve( new XYZ( 50, 50, 0 ), 10, 10, XYZ.BasisX, XYZ.BasisY, 0, 2 * Math.PI );
          Document.Create.NewModelCurve( circle, sketch.SketchPlane );
    public class FailuresPreprocessor : IFailuresPreprocessor
      public FailureProcessingResult PreprocessFailures(
        FailuresAccessor failuresAccessor )
        return FailureProcessingResult.Continue;
I hope this helps.
jeremy_tammik
Added the raw sample code to The Building Coder samples:
https://github.com/jeremytammik/the_building_coder_samples/compare/2022.0.150.4...2022.0.150.5
zhuliyi0
Thanks Jeremy, this solves my problem. I need to use Preview Forum more : )
n_mulconray
I have just tried to get this great addition to the revit api to do the simple task of replacing one line with a line that is not off axis.
I am the start stage where I have tried to run the module posted by Jeremmy, thanx btw.
I am getting as far as deletion and then the exceptions might be swallowed by the failures preprocessor, however i am not seeing the line update, i am using metric revit and calling in a modeless dialog context from an external command. I noticed the arc is nearly twice the line segment length and so the line and arc are generated successfully, not sure why the delete command? might be stalling.
using (Transaction t = new Transaction(doc, "Modify Sketch"))
   t.Start();
    XYZ normal = line.Direction.CrossProduct(XYZ.BasisZ).Normalize().Negate();
    XYZ middle = line.GetEndPoint(0).Add(line.Direction.Multiply(line.Length / 2));
    Curve arc = Arc.Create(line.GetEndPoint(0), line.GetEndPoint(1), middle.Add(normal.Multiply(20)));
//can get line and arc length
    doc.Delete(line.Reference.ElementId);
//nothing returned here as task dialog nor error...
    TaskDialog.Show("del", "delete");
    ModelCurve mc = doc.Create.NewModelCurve(arc, sketch.SketchPlane);
t.Commit();
public FailureProcessingResult PreprocessFailures(FailuresAccessor failuresAccessor)
n_mulconray
No worries this is solved by copy pasting from the github instead of the forum the sketch edit group trtansaction section of the code. I noted comma errors in VS and this might be the reason or maybe I made some error.
