Can Revit install on Macbook Air ?
thuong_kkt53
thuong_kkt53
Dear Sir,
Currently, I am using Macbook Air, I do not know whether Revit can be installed on Mac or not ?
Tks
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @thuong_kkt53 ,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us.
Installation and licensing forum:
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
I hope this clarifies.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
