Can I develop a Revit AddOn with .NET Framework 4.7.2
rossen.hristov
rossen.hristov
Can I develop a Revit AddOn with .NET Framework 4.7 and use it in old Revit versions such as 2015, 16, 17 and 18. I know that Revit 2019 moved to .NET 4.7, but what about the previous versions.
In other words, if an older installation of Revit uses an older .NET version, for example 2015 uses .NET 4.5, can I develop my Add-On with a newer version of .NET like 4.7? Will Revit 2015 be able to load such an add-on developed with a newer version of the .NET platform. This all is assuming that this newer version of NET is installed on the machine.
jeremytammik
Nobody can answer this question without testing.
Please test and let us know the result.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
rossen.hristov
Yes. It is possible.
ChengboZhang
haha
