Can anyone tell me why view port variable always comes back null? The parameters of Viewport.Create are not null.
ed_sa
Message 1 of 38
ed_sa
using Autodesk.Navisworks.Api;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Windows.Forms;
using Document = Autodesk.Revit.DB.Document;
using Transaction = Autodesk.Revit.DB.Transaction;
using View = Autodesk.Revit.DB.View;
namespace RevitAPI_JBA_Development_2022
[Transaction(TransactionMode.Manual)]
public class GetDraftViewToSheetElementTransformUtils : IExternalCommand
public UIApplication uiApp;
public UIDocument uiDoc;
public Document doc;
public Document externalDoc;
public List<ViewDrafting> draftingViewsFromExternalDoc;
public List<Autodesk.Revit.DB.ViewSheet> sheets;
public ICollection<ElementId> copiedViewElementIds;
SelectDraftingViewForm viewForm;
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiApp = commandData.Application;
UIDocument uiDoc = uiApp.ActiveUIDocument;
Autodesk.Revit.DB.Document doc = uiDoc.Document;
using (Autodesk.Revit.DB.Transaction docTransaction = new Transaction(doc, "Process Drafting Views"))
try
docTransaction.Start();
string selectedFilePath = BrowseForFile();
if (selectedFilePath == null)
TaskDialog.Show("Message", "Error: File not selected");
return Result.Cancelled;
externalDoc = uiApp.Application.OpenDocumentFile(selectedFilePath);
//TaskDialog.Show("Print", $"{externalDoc}");
if (externalDoc == null)
TaskDialog.Show("Error", $"Failed to open the external document: {selectedFilePath}");
return Result.Failed;
draftingViewsFromExternalDoc = GetDraftingViews(externalDoc);
sheets = GetSheets(doc);
if (draftingViewsFromExternalDoc == null || draftingViewsFromExternalDoc.Count == 0)
TaskDialog.Show("Message", "No drafting views found in the external document.");
externalDoc.Close(true);
// Display a form to select the drafting view
viewForm = new SelectDraftingViewForm(draftingViewsFromExternalDoc, sheets);
if (viewForm.ShowDialog() != DialogResult.OK)
externalDoc.Close(false);
ViewDrafting selectedDraftingView = viewForm.SelectedDraftingView;
//TaskDialog.Show("Print", $"{uiApp}-{doc}-{externalDoc}-{draftingViewsFromExternalDoc}-{viewForm}");
//TaskDialog.Show("Print", $"{draftingViewsFromExternalDoc}");
if (uiApp != null && doc != null && externalDoc != null && draftingViewsFromExternalDoc != null && viewForm != null && selectedDraftingView != null)
try
if (uiApp != null && doc != null && externalDoc != null && draftingViewsFromExternalDoc != null && viewForm != null)
// Place the selected drafting view onto a new sheet in the current document
ViewSheet selectedSheetImport = PlaceDraftingViewOnSheet(doc, selectedDraftingView);
//TaskDialog.Show("Print", $"{newSheet}");
// Close the external document
//externalDoc.Close(false);
// Update existing elements with imported items if they have the same name
//TaskDialog.Show("Print", "Print TaskDialog number one");
UpdateExistingElements(doc, externalDoc);
//TaskDialog.Show("Print", "Print TaskDialog number two");
docTransaction.Commit();
return Result.Succeeded;
else
TaskDialog.Show("Error", "One ofthe items is null!");
catch (Exception ex)
if (docTransaction.GetStatus() == TransactionStatus.Started)
docTransaction.RollBack();
TaskDialog.Show("Error", $"An error occurred: {ex.Message}");
else
TaskDialog.Show("Print", "this is for print");
TaskDialog.Show("Error", $"Failed to place drafting view on sheet: {ex.Message}");
public GetDraftViewToSheetElementTransformUtils()
// Initialize uiApp and uiDoc to null
uiApp = null;
uiDoc = null;
// Initialize other variables
doc = this.doc;
externalDoc = null;
draftingViewsFromExternalDoc = new List<ViewDrafting>();
copiedViewElementIds = new List<ElementId>();
private string BrowseForFile()
using (OpenFileDialog openFileDialog = new OpenFileDialog())
openFileDialog.Filter = "Revit Files (*.rvt)|*.rvt|All files(*.*)|*.*";
openFileDialog.FilterIndex = 1;
openFileDialog.RestoreDirectory = true;
if (openFileDialog.ShowDialog() == DialogResult.OK)
return openFileDialog.FileName;
else
return null;
private List<ViewDrafting> GetDraftingViews(Autodesk.Revit.DB.Document document)
return new FilteredElementCollector(document)
.OfClass(typeof(ViewDrafting))
.Cast<ViewDrafting>()
.ToList();
public List<ViewSheet> GetSheets(Document doc)
return new FilteredElementCollector(doc)
.OfClass(typeof(ViewSheet))
.Cast<ViewSheet>()
.ToList();
//Version 1
//private ViewSheet PlaceDraftingViewOnSheet(Document currentDoc, ViewDrafting draftingView)
// if (currentDoc == null || draftingView == null)
// TaskDialog.Show("Error", "Document or DraftingView is null");
// return null;
// try
// // Retrieve the selected sheet from the combo box
// string selectedSheetName = viewForm.sheetComboBox.SelectedItem as string;
// if (string.IsNullOrEmpty(selectedSheetName))
// TaskDialog.Show("Error", "No sheet selected");
// return null;
// // Retrieve the selected sheet from the list of sheets
// ViewSheet selectedSheet = sheets.FirstOrDefault(sheet => sheet.Name == selectedSheetName);
// if (selectedSheet == null)
// TaskDialog.Show("Error", $"Selected sheet '{selectedSheetName}' not found");
// return null;
// // Copy the drafting view to the selected sheet
// ElementId copiedViewElementId = ElementTransformUtils.CopyElements(externalDoc, new List<ElementId> { draftingView.Id }, currentDoc, null, null).First();
// if (copiedViewElementId == null || copiedViewElementId == ElementId.InvalidElementId)
// TaskDialog.Show("Error", "Failed to copy the drafting view to the sheet");
// return null;
// copiedViewElementIds.Add(copiedViewElementId);
// Element copiedElement = currentDoc.GetElement(copiedViewElementId);
// if (copiedElement is ViewDrafting copiedView)
// // Create a new viewport for the drafting view
// Viewport viewport = Viewport.Create(currentDoc, selectedSheet.Id, copiedView.Id, XYZ.Zero);
// if (viewport == null)
// TaskDialog.Show("Error", "Failed to create viewport for the drafting view");
// return null;
// return selectedSheet;
// catch (Exception ex)
// TaskDialog.Show("Error", $"An error occurred: {ex.Message}");
// return null;
//Version 2
// return null;
// try
// // Create a new sheet
// //ViewSheet newSheet = ViewSheet.Create(currentDoc, ElementId.InvalidElementId);
// // Retrieve the list of sheets from the current document
// List<ViewSheet> sheets = new FilteredElementCollector(currentDoc)
// .OfClass(typeof(ViewSheet))
// .Cast<ViewSheet>()
// .ToList();
// if (sheets == null)
// TaskDialog.Show("Error", "Failed to create a new sheet");
// return null;
// //TaskDialog.Show("Print", $"new Sheet{newSheet}");
// // Copy the drafting view to the new sheet
// //TaskDialog.Show("Print", $"copied View element Id{copiedViewElementId}");
// TaskDialog.Show("Error", "Failed to copy the drafting view to the new sheet");
// return null;
// //TaskDialog.Show("Print", $"copied Element{copiedElement}");
// //TaskDialog.Show("Print", $"{copiedView}-{currentDoc}-{newSheet}much before");
// //TaskDialog.Show("Print", $"{copiedView}-{currentDoc}-{newSheet} Before that");
// try
// //TaskDialog.Show("Print", $"{copiedView}-{currentDoc}-{newSheet} Before it");
// if (copiedView != null && currentDoc != null && newSheet != null)
// Viewport viewport = Viewport.Create(currentDoc, newSheet.Id, copiedView.Id, XYZ.Zero);
// return null;
// //TaskDialog.Show("Print", $"{copiedView}-{currentDoc}-{newSheet} Afterwards");
// else
// TaskDialog.Show("Error", "One of the items is null");
// TaskDialog.Show("Error", $"{ex.Message}");
// return sheets;
// return null;
//Version 3
return null;
try
return null;
return null;
ElementId copiedViewElementId = ElementTransformUtils.CopyElements(externalDoc, new List<ElementId> { draftingView.Id }, currentDoc, null, null).FirstOrDefault();
return null;
// Get the copied drafting view element
return null;
else
TaskDialog.Show("Error", "Copied element is not a drafting view");
return null;
return null;
private void UpdateExistingElements(Document currentDoc, Document externalDoc)
// List to store names of imported elements from the external document
List<string> importedElementNames = new List<string>();
// Retrieve names of imported elements from external document
foreach (var elementId in copiedViewElementIds)
Element importedElement = externalDoc.GetElement(elementId);
if (importedElement != null)
string elementName = importedElement.Name;
if (!string.IsNullOrEmpty(elementName))
importedElementNames.Add(elementName);
try
// Iterate over copied view element IDs
foreach (var importedElementId in copiedViewElementIds)
// Retrieve imported element from current document
Element importedElement = currentDoc.GetElement(importedElementId);
string importedElementName = importedElement.Name;
if (!string.IsNullOrEmpty(importedElementName))
// Check if imported element name exists in the current document
if (importedElementNames.Contains(importedElementName))
// Find existing element with the same name
var existingElement = new FilteredElementCollector(currentDoc)
.WhereElementIsNotElementType()
.FirstOrDefault(e => e.Name == importedElementName);
if (existingElement != null)
// Delete existing element
currentDoc.Delete(existingElement.Id);
// Copy imported element to replace existing element
ElementTransformUtils.CopyElement(currentDoc, importedElementId, null);
else
// Check if imported element is a FamilySymbol
FamilySymbol familySymbol = importedElement as FamilySymbol;
if (familySymbol != null)
// Duplicate and activate the FamilySymbol
FamilySymbol newSymbol = familySymbol.Duplicate(importedElementName) as FamilySymbol;
newSymbol.Activate();
else
// Check if imported element is an ElementType
ElementType elementType = importedElement as ElementType;
if (elementType != null)
// Duplicate the ElementType
ElementType newType = elementType.Duplicate(importedElementName) as ElementType;
// Handle any exceptions that occur during the process
//public class SelectDraftingViewForm : System.Windows.Forms.Form
// private System.Windows.Forms.ComboBox comboBox1;
// private Button okButton;
// private Button cancelButton;
// public ViewDrafting SelectedDraftingView { get; private set; }
// public List<ViewDrafting> draftingViewsFromExternalDoc;
// public SelectDraftingViewForm(List<ViewDrafting> draftingViewsFromExternalDoc)
// try
// InitializeComponent();
// this.draftingViewsFromExternalDoc = draftingViewsFromExternalDoc;
// foreach (var draftingView in draftingViewsFromExternalDoc)
// comboBox1.Items.Add(draftingView.Name);
// private void InitializeComponent()
// this.comboBox1 = new System.Windows.Forms.ComboBox();
// this.okButton = new System.Windows.Forms.Button();
// this.cancelButton = new System.Windows.Forms.Button();
// // ComboBox
// this.comboBox1.FormattingEnabled = true;
// this.comboBox1.Location = new System.Drawing.Point(12, 12);
// this.comboBox1.Name = "comboBox1";
// this.comboBox1.Size = new System.Drawing.Size(200, 21);
// this.comboBox1.TabIndex = 0;
// // Ok Button
// this.okButton.Location = new System.Drawing.Point(12, 50);
// this.okButton.Name = "okButton";
// this.okButton.Size = new System.Drawing.Size(75, 23);
// this.okButton.TabIndex = 1;
// this.okButton.Text = "OK";
// this.okButton.UseVisualStyleBackColor = true;
// this.okButton.Click += new System.EventHandler(this.OkButton_Click);
// // Cancel Button
// this.cancelButton.Location = new System.Drawing.Point(137, 50);
// this.cancelButton.Name = "cancelButton";
// this.cancelButton.Size = new System.Drawing.Size(75, 23);
// this.cancelButton.TabIndex = 2;
// this.cancelButton.Text = "Cancel";
// this.cancelButton.UseVisualStyleBackColor = true;
// this.cancelButton.Click += new System.EventHandler(this.CancelButton_Click);
// // Form
// this.ClientSize = new System.Drawing.Size(224, 85);
// this.Controls.Add(this.cancelButton);
// this.Controls.Add(this.okButton);
// this.Controls.Add(this.comboBox1);
// this.Name = "SelectDraftingViewForm";
// this.Text = "Select Drafting View";
// private void OkButton_Click(object sender, EventArgs e)
// try
// string selectedDraftingViewName = comboBox1.SelectedItem as string;
// if (!string.IsNullOrEmpty(selectedDraftingViewName) && draftingViewsFromExternalDoc != null)
// SelectedDraftingView = draftingViewsFromExternalDoc
// .FirstOrDefault(view => view.Name == selectedDraftingViewName);
// DialogResult = DialogResult.OK;
// Close();
// private void CancelButton_Click(object sender, EventArgs e)
// DialogResult = DialogResult.Cancel;
// Close();
public System.Windows.Forms.ComboBox draftingViewComboBox;
public System.Windows.Forms.ComboBox sheetComboBox;
public Button okButton;
public Button cancelButton;
public ViewSheet SelectedSheet { get; private set; }
public List<ViewDrafting> importDraftingViewsFromExternalDoc;
public List<ViewSheet> sheets;
public SelectDraftingViewForm(List<ViewDrafting> draftingViewsFromExternalDoc, List<ViewSheet> sheets)
try
this.importDraftingViewsFromExternalDoc = draftingViewsFromExternalDoc;
this.sheets = sheets;
if (importDraftingViewsFromExternalDoc != null)
foreach (var draftingView in importDraftingViewsFromExternalDoc)
draftingViewComboBox.Items.Add(draftingView.Name);
if(sheets!= null)
foreach (var sheet in sheets)
sheetComboBox.Items.Add(sheet.Name);
this.draftingViewComboBox = new System.Windows.Forms.ComboBox();
this.sheetComboBox = new System.Windows.Forms.ComboBox();
// Drafting View ComboBox
this.draftingViewComboBox.FormattingEnabled = true;
this.draftingViewComboBox.Location = new System.Drawing.Point(12, 12);
this.draftingViewComboBox.Name = "draftingViewComboBox";
this.draftingViewComboBox.Size = new System.Drawing.Size(200, 21);
this.draftingViewComboBox.TabIndex = 0;
// Sheet ComboBox
this.sheetComboBox.FormattingEnabled = true;
this.sheetComboBox.Location = new System.Drawing.Point(12, 40);
this.sheetComboBox.Name = "sheetComboBox";
this.sheetComboBox.Size = new System.Drawing.Size(200, 21);
this.sheetComboBox.TabIndex = 1;
// Ok Button
this.okButton.Location = new System.Drawing.Point(12, 80);
this.okButton.TabIndex = 2;
// Cancel Button
this.cancelButton.Location = new System.Drawing.Point(137, 80);
this.cancelButton.TabIndex = 3;
// Form
this.ClientSize = new System.Drawing.Size(224, 120);
this.Controls.Add(this.sheetComboBox);
this.Controls.Add(this.draftingViewComboBox);
try
string selectedDraftingViewName = draftingViewComboBox.SelectedItem as string;
string selectedSheetName = sheetComboBox.SelectedItem as string;
if (!string.IsNullOrEmpty(selectedDraftingViewName) && !string.IsNullOrEmpty(selectedSheetName))
SelectedDraftingView = importDraftingViewsFromExternalDoc
SelectedSheet = sheets.FirstOrDefault(sheet => sheet.Name == selectedSheetName);
Close();
Close();
Replies (37)
Message 2 of 38
TripleM-Dev.net
I've only looked at the line with "Viewport.Create", it says something about a drafting view.
Are you creating a Viewport of a drafting view?
A drafting views needs to contain some geometry, a empty drafting view can't be placed on a sheet.
- Michel
ps. Use Insert/Edit Code sample button to share code.
Message 3 of 38
ed_sa
very nice. I will check on the geometry aspect. Would that have anything to do with XYZ.Zero, is recalculating the xyz a necessity?
Message 4 of 38
ed_sa
By the way, they all contained geometry. would a geometry check/match of length and width matter at this point?
Message 5 of 38
TripleM-Dev.net
The actual draftview needs to have geometry to be placed on a sheet.
Test it in the Revit UI manually, it will give a message that a empty draftview can't be placed.
There needs to be a detailline, text or another annotation element on the draftview in order to place it on a sheet.
- Michel
Message 6 of 38
TripleM-Dev.net
What do you mean "They all contained Geometry", the draftviews?
Check if the draftview has any elements with FilteredElementCollector and as viewargument the draftview, if it has it's should be good to be placed on a sheet.
Message 7 of 38
ed_sa
I mean they all have elements. they're not blank. All you have to do is look at the draft view, I suppose I could run filteredlementcollector, but I assume that would show me the same in numbers.
Message 8 of 38
TripleM-Dev.net
Are you placing a draftview from one model onto a sheet in another model?
Message 9 of 38
ed_sa
exactly right? I open the file browser as it is prompted that collects all draftviews, converts to string puts them on combobox, then does the same for sheets in current document. then I choose which draft view to import along with which sheet to input it to. I calculate the sheet and draft view size to see if they fit, I then input the draft view in the center of the sheet using viewport.create and elementtransformutils.movelement. the latter to make sure the center of the draft view is the same as center of sheet. Then I get this error saying that elementToMove doesn't exist.  Im just now adding a null check for draft view right before the elementTransformUtils.MoveElement in " ElementTransformUtils.MoveElement(currentDoc, draftingView.Id, sheetCenter - CalculateDesiredPositionInView(draftingView));"  Being the case the draft views come from outside , should it make any difference in this? Thank you for very good question.
Message 10 of 38
ed_sa
exactly right I meant. no question mark.
Message 11 of 38
TripleM-Dev.net
That's not possible, the view for the viewport has to be in the same document as the sheet.
As general rule if it's not possible in the Revit UI manually, then it's also not possible in the API.
Message 12 of 38
ed_sa
I have to disagree with that last part. First insert from file in the insert tab, does just that, second, adjusting object styles settings collectively is not possible in the UI but it's possible programmatically, I can attest. I think it is possible also based on what you're saying therefore..
Message 13 of 38
TripleM-Dev.net
Ok, we're getting there. The code you posted is hard to make out due to the large commented sections.
You're copying the draftview from one model to another, that's possible.
Next you get the ElementId of the newly created draftview to place on sheet.
All these steps separately are ok, but I don't think they can be combined in one transaction (or the issue is the way the original document is opened)
Do all the seperate tasks work (split the code), I think the copying of the draftview and the creation of the viewport need their own transaction. Give them both their own transaction and place those in a Transaction group.
Message 14 of 38
ed_sa
sounds interesting. Why do you think that would solve the problem?
Message 15 of 38
ed_sa
here is my revised code:
using System;
using System.Linq;
try
doc.Regenerate();
doc.Regenerate();
try
ViewSheet selectedSheetImport = PlaceDraftingViewOnSheet(doc, selectedDraftingView, viewForm, sheets);
doc.Regenerate();
else
else
uiApp = null;
uiDoc = null;
//doc = this.doc;
externalDoc = null;
else
return null;
.ToList();
.Cast<ViewSheet>()
.ToList();
//Version 3
// return null;
// try
// return null;
// return null;
// // Validate the sheet and drafting view dimensions
// if (!ValidateSheetAndDraftingView(selectedSheet, draftingView))
// return null; // Validation failed
// ElementId copiedViewElementId = ElementTransformUtils.CopyElements(externalDoc, new List<ElementId> { draftingView.Id }, currentDoc, null, null).FirstOrDefault();
// return null;
// // Get the copied drafting view element
// if (copiedElement is ViewDrafting copiedView && draftingView != null)
// // Calculate the center point of the sheet
// XYZ sheetCenter = CalculateSheetCenter(selectedSheet);
// // Place the drafting view at the center of the sheet
// ElementTransformUtils.MoveElement(currentDoc, draftingView.Id, sheetCenter - CalculateDesiredPositionInView(draftingView));
// currentDoc.Regenerate();//Ensure model updates before creating viewport
// Viewport viewport = Viewport.Create(currentDoc, selectedSheet.Id, copiedView.Id, sheetCenter);
// return null;
// else
// TaskDialog.Show("Error", "Copied element is not a drafting view");
// return null;
// return null;
//Version 4
private ViewSheet PlaceDraftingViewOnSheet(Document currentDoc, ViewDrafting draftingView, SelectDraftingViewForm viewForm, List<ViewSheet> sheets)
// Check if the required parameters are null
if (currentDoc == null || draftingView == null || viewForm == null || sheets == null)
TaskDialog.Show("Error", "One or more required parameters is null");
return null;
try
// Retrieve the selected sheet name from the combo box
return null;
return null;
// Copy the drafting view to the current document
return null;
// Store the copied view element ID for later use
if(copiedView != null)
// Calculate the desired position of the drafting view within the sheet
XYZ desiredPositionInView = CalculateDesiredPositionInView(draftingView);
// Move the drafting view to the calculated position within the sheet
ElementTransformUtils.MoveElement(currentDoc, copiedView.Id, sheetCenter - desiredPositionInView);
currentDoc.Regenerate(); // Ensure model updates before creating viewport
TaskDialog.Show("Error", "Failed to create viewport for the drafting view !");
return null;
// Return the selected sheet
else
return null;
else
return null;
return null;
private XYZ CalculateDesiredPositionInView(ViewDrafting draftingView)
// Example: Calculate the center point of the drafting view
BoundingBoxUV outline = draftingView.Outline;
UV minPoint = outline.Min;
UV maxPoint = outline.Max;
XYZ viewCenter = new XYZ((minPoint.U + maxPoint.U) / 2, (minPoint.V + maxPoint.V) / 2, 0);
return viewCenter;
private XYZ CalculateSheetCenter(ViewSheet sheet)
// Retrieve the outline of the sheet
BoundingBoxUV outline = sheet.Outline;
XYZ sheetCenter = new XYZ((minPoint.U + maxPoint.U) / 2, (minPoint.V + maxPoint.V) / 2, 0);
return sheetCenter;
private double GetSheetWidth(ViewSheet sheet)
// Retrieve the width of the sheet from its BoundingBox
BoundingBoxUV boundingBox = sheet.Outline;
return boundingBox.Max.U - boundingBox.Min.U;
private double GetSheetLength(ViewSheet sheet)
// Retrieve the length of the sheet from its BoundingBox
return boundingBox.Max.V - boundingBox.Min.V;
private double GetDraftingViewWidth(ViewDrafting draftingView)
// Retrieve the width of the drafting view from its BoundingBox
BoundingBoxUV boundingBox = draftingView.Outline;
private double GetDraftingViewLength(ViewDrafting draftingView)
// Retrieve the length of the drafting view from its BoundingBox
private bool ValidateSheetAndDraftingView(ViewSheet sheet, ViewDrafting draftingView)
// Retrieve dimensions of the sheet and drafting view
double sheetWidth = GetSheetWidth(sheet);
double sheetLength = GetSheetLength(sheet);
double draftingViewWidth = GetDraftingViewWidth(draftingView);
double draftingViewLength = GetDraftingViewLength(draftingView);
// Check if the drafting view fits within the sheet boundaries
if (draftingViewWidth <= sheetWidth && draftingViewLength <= sheetLength)
return true; // Validation successful
else
TaskDialog.Show("Validation Error", "Drafting view dimensions exceed sheet boundaries.");
return false; // Validation failed
try
else
else
try
if(sheets!= null)
// Sheet ComboBox
// Ok Button
// Cancel Button
// Form
try
Close();
Close();
Message 16 of 38
ed_sa
nevermind, disregard that. just the comment section remove it my bad. I can't delete it.
Message 17 of 38
TripleM-Dev.net
For some tasks Revit needs to refresh the database, and that's only possible after a transaction.
Transactiongroup is not needed, but makes the handling as one function (undo for user) else the addin will create 2 steps, one for each transaction.
I don't know if this solves it.
Does the CopyElements itself work, does the Draftview show up in the document?
Message 18 of 38
ed_sa
for database regeneration I have doc.Regenerate() I hope thats working. it seems to . for copyElements it does work, because the copiedViewElementId variable is not null when debugging. Please run this code on your side, it's applicable, see if you get the error, just copy paste shouldn't be an issue.
Message 19 of 38
ed_sa
this is where I get the error: // Create a new viewport for the drafting view
return null;
} viewport comes back null. It might be a revit api permissions thing. the draftview is imported just fine, and all argument for Viewport.Create are not null, place a breakpoint there and tell me what you get. I think two transactions within the execute method might solve the issue.
Message 20 of 38
TripleM-Dev.net
The copiedViewElementIds variable is never initialized, I changed into a List and initialized it.
Futher I also then get the error on the Creation of viewport, the Draftview exists in the model but is empty, it didn't copy it's content.
It's possible the view itself only gets copied and not it's content.
The error of the Viewport would then be because it's empty.
Maybe You also need to copy the content over from the other model?
