Calling IExternalCommand from WPF button
cugelkater
cugelkater
Hello. I have the class SaveSectionBoxInfo in the IExternalCommand interface. I want to call it through button in the WPF form. There is error CS1729 'ExternalCommandData' does not contain a constructor that takes 0 arguments (marked by comment). I can't find the right argument for 'ExternalCommandData'. How can I do it properly? And is it correct to use the IExternalCommand interface in this case? Thanks for your answers.
WPF:
    public partial class BbWPF : Window
        private readonly UIApplication _uiApp;
        public BbWPF(UIApplication uiApp)
            InitializeComponent();
            _uiApp = uiApp;
        public ExternalCommandData commandData { get; set; }
        private void BbWPFsavePos_Click(object sender, RoutedEventArgs e)
            SaveSectionBoxInfo command = new SaveSectionBoxInfo();
// here CS1729  'ExternalCommandData' does not contain a constructor that takes 0 arguments
            ExternalCommandData commandData = new ExternalCommandData();
            string message = string.Empty;
            ElementSet elements = new ElementSet();
            Result result = command.Execute(commandData, ref message, elements);
Class:
   [Transaction(TransactionMode.Manual)]
   public class BoxMenu : IExternalCommand
       public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
           UIApplication uiApp = commandData.Application;
           BbWPF window = new BbWPF(uiApp);
           window.ShowDialog();
           return Result.Succeeded;
   public class SaveSectionBoxInfo : IExternalCommand
           UIDocument uiDoc = commandData.Application.ActiveUIDocument;
           Document doc = uiDoc.Document;
           View3D view3D = doc.ActiveView as View3D;
           if (view3D != null && view3D.IsSectionBoxActive)
               BoundingBoxXYZ sectionBox = view3D.GetSectionBox();
               XYZ min = sectionBox.Min;
               XYZ max = sectionBox.Max;
               XYZ center = (min + max) / 2;
               XYZ size = max - min;
               TaskDialog.Show("Coords:", $"Center: {center}\nSize: {size}");
           else
               TaskDialog.Show("Error", "Error");
jeremy_tammik
Look at the official Revit SDK sample ModelessDialog/ModelessForm_ExternalEvent. For further info, check out the numerous previous discussions on Idling and External Events for Modeless Access and Driving Revit from Outside:
Moustafa_K
does this answer helps
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
jeremy_tammik
Here is yet another (and maybe the most recent) modeless add-in tutorial on ho to create a Revit add-in with a modeless WPF window and XAML, by Sergei Nefedov:
cugelkater
Thanks you all for replies, after endless attempts this one helped:
https://forums.autodesk.com/t5/revit-api-forum/call-class-from-windows-form/td-p/5984297
