Call IExternalCommand from dll in project code
vankhoi9966
vankhoi9966
In my dll file is Namespace.class1
How can I execute Namespace.class1 into my new code project?
sorry, I'm from VietNam.....I have to use google translate
thanks all
jeremytammik
If your intention is to execute an external command, and you are searching for the full class name, I suggest you follow the 'Hello World' samples provided by the Revit API developer guide:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-93BC4416-FA94-44B3-AA66-931839DA44B4
I hope this helps.
Best regards,
jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
vankhoi9966
Dear jeremy...
thanks for the reply .... but that's not what i need ...
I need a function that can replace the click on the button ....
I heard using reflection in C # but I do not know how to do it ...
Again thank you ...
jeremytammik
You can use the Automation AP|I to simulate a click:
http://thebuildingcoder.typepad.com/blog/2017/12/magic-number-magic-automation-and-magic-season.html...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
vankhoi9966
Thanks Jeremy.... (y)
