Calculate the intersection of 3 reference planes of a family
Hi all,
I am trying to calculate the intersection of 3 reference planes of a family. Is that possible?
For now I have the reference of the three planes:
Reference refx = FamilyInstance.GetReferenceByName("pX");
Reference refy = FamilyInstance.GetReferenceByName("pY");
Reference refz = FamilyInstance.GetReferenceByName("pZ");
jeremytammik
In order to be productive, you will first of all need to learn to search the Internet yourself.
One good place to start for all generic questions like this is Wikipedia:
https://en.wikipedia.org/wiki/Plane_(geometry)
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
mastjaso
Hi Jeremy, I believe the issue is that Revit does not return a plane object, but a "Reference" object. I've been hunting for several hours but can seem to find no way of getting the plane object from the reference.
FrankHolidaytoiling
I am getting the same ref planes endpoints returned for this method, i draw circles in plan to view where the endpoints are, if i use the bubbles i get "cant use unbound curve" and if i create sketch planes, the circles i draw in plan are identical, i would expect the perpendicular ref plane to be returned froma  collector and the next one after zero index would be the next one with the origin_datum_plane is set to 1 or checked.
private static XYZ CheckForIntersection(ICollection<ReferencePlane> referencePlanes)
if (referencePlanes.Count < 3)
throw new Exception("Not enough reference planes");
ReferencePlane refPlane1 = referencePlanes.ElementAt(0);
ReferencePlane refPlane2 = referencePlanes.ElementAt(1);
ReferencePlane refPlane3 = referencePlanes.ElementAt(2);
Line line1;
Line line2;
Line line3;
using (Transaction t = new Transaction(Doc, "drawrp"))
t.Start();
Plane plan = SketchPlane.Create(Doc, refPlane1.Id).GetPlane();
line1 = Line.CreateBound(plan.Origin, plan.Origin + 1 * plan.XVec);
OperationsDraw.DrawCircle(Doc, line1.GetEndPoint(0).X, line1.GetEndPoint(0).Y, 0.5);
OperationsDraw.DrawCircle(Doc, line1.GetEndPoint(1).X, line1.GetEndPoint(1).Y, 0.5);
Plane plan2 = SketchPlane.Create(Doc, refPlane2.Id).GetPlane();
line2 = Line.CreateBound(plan2.Origin, plan2.Origin + 1 * plan2.XVec);
OperationsDraw.DrawCircle(Doc, line2.GetEndPoint(0).X, line2.GetEndPoint(0).Y, 0.75);
OperationsDraw.DrawCircle(Doc, line2.GetEndPoint(1).X, line2.GetEndPoint(1).Y, 0.75);
Plane plan3 = SketchPlane.Create(Doc, refPlane3.Id).GetPlane();
line3 = Line.CreateBound(plan3.Origin, plan3.Origin + 1 * plan3.YVec);
t.Commit();
IntersectionResultArray results;
SetComparisonResult result = line1.Intersect(line2, out results);
if (result == SetComparisonResult.Overlap && results != null && results.Size > 0)
return results.get_Item(0).XYZPoint;
result = line1.Intersect(line3, out results);
result = line2.Intersect(line3, out results);
MessageBox.Show("Intersection not found");
return null;
jeremy_tammik
Rather belatedly, I would suggest using the Document GetElement method taking a Reference argument:
https://www.revitapidocs.com/2024/4d674a3e-cd18-6b3d-b1b2-247713fe3c9f.htm
