c++ revit api. Getting element categories from model.
halukuzuner
halukuzuner
Dear friends. I am new to Revit API world. I am trying to get element categories from model but I get following error. Can someone help me to get over this problem? Visual C++ project is also attachedç
joshua.lumley
Revit API works with C#, Python, VB & Ruby.   Most almost everybody in this forum use the .net framework with C#.
To get a list of all the categores use: doc.Settings.Categories
halukuzuner
Yes it seems only fewer people use C++ for revit API. I only know C++. so that I am trying C++.
joshua.lumley
I don't think the learning curve is as steep as you imagine. Just start with Taskdialogue.show("Me", "Hello World");  It will only take you a few days to pick up speed because c# is easier then c++ and the projects compile lightning fast.
halukuzuner
I have already done "hello revit" addin. It works fine. But my problem is accessing model elements from the form wihich I created.
joshua.lumley
Try accessing just one with the element ID and the document.
Element myElement = doc.getElement(new elementid(12345));
halukuzuner
Dear Joshua,
Thanks for your replies. My problem is accesing cached "CachedDoc" variable from "MyForm.h". If I could acces that document from MyForm I will be able to use the syntax you mentioned. Revit API.png
