C# revit API - CREATE PARAMETER FILTER - SETRULES METHOD DEPRECATED
Hello Everyone,
I try to solve a problem since a moment, but I did not find the solution yet.
I use REVIT 2019.
In this version I use "SetRules" Method in a macro which has to create Parameter filters.
This Method works today in REVIT 2019.
But When compiling the code, I have a warning message. It warns me against the Method "SetRules" which is deprecated and will not be available anymore in the next version of REVIT.
It suggests me to use the method "SetElementFilter" instead of "SetRules".
But I Don't find any example of this new Method.
Moreover these two methods Don't have the same entry argument.
Setrules has a list of Filterrule as entry argument
SetElementFilter would have ElementFilter as entry argument
Could someone help me concerning this problem? Can we have a example that works?
On Autodesk
Thank you Very much
LD
JimJia
Hi
You may noticed that the ElementParameterFilter is derived class of ElementFilter.
So, you can create ElementParameterFilter with origin FilterRules and then use these ElementParameterFilter for SetElementFilter.
Find more details about the ElementParameterFilter API here:
http://www.revitapidocs.com/2018.1/b0b40351-690c-eb5d-30c2-d4447a42fda1.htm
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Hi
Could you give me an example please?
lwlXUTTT
instead of using
ParameterFilterElement.SetRules(fRules)
you need to use
ParameterFilterElement.SetElementFilter(new ElementParameterFilter(fRules))
hope that helps,
Best, Luki
Thank you very much
That is exactly what I am looking for.
Thank's
