BuildWindowCore failed to return the hosted child window handle
harilalmnCBXDY
harilalmnCBXDY
I have tried my best to resolve this. Any help would be greatly appreciated.
I am trying to create a plug in which should entirely run in a Dockable Pane. When I close the revit documentI get the following error message:
System.InvalidOperationException
HResult=0x80131509
Message=BuildWindowCore failed to return the hosted child window handle.
Source=PresentationFramework
The implementation is as follows;
The IExternalApplication
public class Main : IExternalApplication
    public Result OnShutdown(UIControlledApplication application)
        return Result.Succeeded;
    public Result OnStartup(UIControlledApplication application)
        MyPage page1 = new MyPage();
        application.RegisterDockablePane(DockablePaneIdProvider.GetDockablePaneId(), "MyPage", (MyPage)page1);
The IExternalCommand
public class Dockable : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        try
            UIApplication uiapp = commandData.Application;
            Document document = uiapp.ActiveUIDocument.Document;
            // Show the dockable pane
            DockablePane dockablePane = uiapp.GetDockablePane(DockablePaneIdProvider.GetDockablePaneId());
            dockablePane.Show();
        catch (Exception ex)
            message = ex.Message;
            return Result.Failed;
The xaml.cs for the Page
 public partial class MyPage : Page, IDockablePaneProvider
     public MyPage()
         InitializeComponent();
     public void SetupDockablePane(DockablePaneProviderData data)
         data.FrameworkElement = this as FrameworkElement;
         data.InitialState.DockPosition = DockPosition.Tabbed;
The DockablePaneIdProvider
public class DockablePaneIdProvider
    public static DockablePaneId GetDockablePaneId()
        DockablePaneId paneId = new DockablePaneId(new Guid("3BC54A55-CB65-48F1-9520-A1B2523823A7"));
        return paneId;
ricaun
Your code looks fine.
What do you have inside the xaml? My guess is something in there, like a webview or some unusual component.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
harilalmnCBXDY
@ricaun
I have a TabControl in it, with 5 TabItems.
<Page
    x:Class="DocakbleUI.MyPage"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
    xmlns:local="clr-namespace:DocakbleUI"
    xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
    d:DesignHeight="450"
    d:DesignWidth="800"
    Background="#2F2F2F"
    Foreground="#BFBFBF"
    mc:Ignorable="d">
    <Page.Resources>
        <Style TargetType="TabControl">
            <Setter Property="Background" Value="Transparent" />
            <Setter Property="Margin" Value="5" />
            <Setter Property="TabStripPlacement" Value="Right" />
            <Setter Property="Template">
                <Setter.Value>
                    <ControlTemplate TargetType="TabControl">
                        <Grid>
                            <Grid.ColumnDefinitions>
                                <ColumnDefinition Width="*" />
                                <ColumnDefinition Width="Auto" />
                            </Grid.ColumnDefinitions>
                            <ContentPresenter
                                Grid.Column="0"
                                Content="{TemplateBinding SelectedContent}"
                                ContentStringFormat="{TemplateBinding SelectedContentStringFormat}"
                                ContentTemplate="{TemplateBinding SelectedContentTemplate}" />
                            <ScrollViewer
                                Grid.Column="1"
                                HorizontalScrollBarVisibility="Disabled"
                                VerticalScrollBarVisibility="Auto">
                                <TabPanel
                                    Background="{TemplateBinding Background}"
                                    IsItemsHost="True"
                                    KeyboardNavigation.TabIndex="1" />
                            </ScrollViewer>
                        </Grid>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
        </Style>
    </Page.Resources>
    <Grid>
        <TabControl>
            <TabItem Name="tb_dashboard">
                <TabItem.Header>
                    <TextBlock Padding="15,0">
                        <TextBlock.LayoutTransform>
                            <RotateTransform Angle="270" />
                        </TextBlock.LayoutTransform>
                        Tab1
                    </TextBlock>
                </TabItem.Header>
            </TabItem>
            <TabItem Name="tb_1">
                <TabItem.Header>
                        Tab2
                    </TextBlock>
                </TabItem.Header>
            </TabItem>
            <TabItem Name="tb_2">
                <TabItem.Header>
                        Tab3
                    </TextBlock>
                </TabItem.Header>
            </TabItem>
            <TabItem Name="tb_3">
                <TabItem.Header>
                        Tagging Issues
                    </TextBlock>
                </TabItem.Header>
            </TabItem>
            <TabItem Name="tb_4">
                <TabItem.Header>
                        Tab4
                    </TextBlock>
                </TabItem.Header>
            </TabItem>
            <TabItem Name="tb_5">
                <TabItem.Header>
                        Tab5
                    </TextBlock>
                </TabItem.Header>
            </TabItem>
        </TabControl>
    </Grid>
</Page>
ricaun
@harilalmnCBXDYare you sure the dockable is cause the BuildWindowCore issue?
What Revit version are you using?
If you create a empty Page with a simple background color the issue happens?
DockablePane is weird when a document is closed the dockable is unload, could be something with that.
harilalmnCBXDY
I am using Revit 2022 version.
Actually my project has a MainWindow which is as WPF window, called from the command as MainWindow.Show();
That also throws the same exception and crashes.
As i have in my initial code I shared, the MainWindow of my project also has a TabControl as its content with several TabItems. The plugin runs fine. But if I close the document and try to open another document (or the same document), it crashes. That is when I tought of checking if a DocablePane would work. Tried my best in several ways like, extending the MainWindow with IDisposible, setting its owner to be Revit's window etc... nothing seemed working! Hence the post.
Attached is a video of the DockablePane crashing Revit.
ricaun
Hmmm, is kinda hard to know what is creating the issue is you are running more code at the same time.
If MainWindow was already breaking the problem could be in there. I don't know what you are doing to binding stuff in the xaml.
The code you show to register a Dockable Pane should work, so I suggest you to comment all the code that is not related to register a Dockable Pane with a color to check if works. You could create a new project as well.
harilalmnCBXDY
I had removed everything I had from the Addins folder except for PyRevit, AddinManager and RevitLookup. Rebuilt everything and this time it worked...!
But I don't know how to recreate the bug,  hence the problem, though it is temporarily somehow resolved, the possibility of it getting back anytime, is a concern. Ah.. will see that then.
@ricaun Thanks for your responses...
