Building masses are not showing in 3D View
ravishankar.unipune
Observer
ravishankar.unipune
Observer
Observer
Hi All
I am trying to build a solution that would make building masses from GeoJSON coordinate. In 2D view, all building contours get created and visible , but In 3D view no 3D Revit masses get visible.
When I search through element ID, then Revit masses get visible too far from the origin.
Please help me to solve this issue via Revit API and other settings Revit.
jeremy_tammik
Before addressing this programmatically through the API, it will help to get things sorted manually in the end user interface. Solve your task successfully in the UI, then analyse the results in the Revit database using RevitLookup and other database analysis tools. That will simplify your way forward to a successful API solution. This is the standard approach to address a Revit API programming task:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
