Bug: Unable to open Revit 2019 model after saving custom schema in Project Info
Hello, I seem to running into an issue that is specific to Revit 2019, as it does not happen in 2017, 2018 and 2020 (using the exact same code).
For my addin I want to save data into the project information of the document using a custom schema. This is generated using the SchemaBuilder class, where I set the schema properties using the example as shown in the API documation.
Adding the schema as a new entity to the document in a transaction succeeds.
And I can use Revit Lookup to inspect the saved data in the document.
Now here's the problem that occurs:
I save the document, with the custom schema added, as a new file.
I close the document.
I re-open the newly saved document, and I get the following errors:
First error on open:
First error on open
Second error on open:
Now I'm unable to open the Revit document.
This can be fixed by opening the document with the Audit checkbox enabled.
Where it prompts the following popup:
Where pressing Repair and open will clear any existing Project Information that was stored, and regenerate the default Project Information fields with empty values.
Could anybody help me with this?
