Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Bug Report: DirectShape mirroring doesn't work.
6 REPLIES 6
CompApp
295 Views, 6 Replies
Hi all,
I've pondered a lot over where I should post this issue. I went with the API Board since you can only create DirectShapes via the API, but I don't think this is an API issue. If this isn't the right place, let me know and I'll head over to the Revit Architecture Forum.
I'm trying to use the mirror function from the Modify panel on a DirectShape (see the image below). The software just duplicates the object over the original one, in the same position. For other elements, like beams and walls, the mirror functions works well.
I'm attaching a rvt project with a DirectShape in it and also a C# project for creating a simple DirectShape.
Thank you and best regards,
Doinas Muresan
6 REPLIES 6
jeremytammik
in reply to: CompApp
Dear Doinas,
Thank you for your report and for your thoughts about where to post it.
In this case, I agree that here is fine.
I'll check with the development team what the expected behaviour is, and create a development database entry for you if this is unintentional.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
jeremytammik
Dear Doinas,
The development team respond:
It works fine for us, using both your model and using the add-in you attached.
What version are you working with?
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
CompApp
in reply to: jeremytammik
Dear Jeremy,
Firstly, again, many thanks for your help and implication.
This is a screen shot from the "About" dialog box:
In the Autodesk Desktop App I don't see any new Revit updates, but i have some "Ehnancements" and Utilities that i didn't install.
Best regards,
Doinas
jeremytammik
Dear Doinas,
Can you please provide a journal file that reproduces the problem?
The development team tried it with a development build of Revit and with Revit 2017 R2 local debug, and it worked as expected.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
jeremytammik
Dear Doinas,
Please disregards the last message.
Here is a new update from the development team, saying:
Yes, we did have this in 2017 but we have since fixed it in R2.
You may be able to work around it by copying, or simply upgrading.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
CompApp
Dear Jeremy,
As far as I know and judging by the info on the webpage below, I'm already upgraded to the latest version.
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
I'll just wait for the next update or for Revit 2018.
Thanks for your time, I know how busy you are. Much appreciated!
Best regards,
Doinas
Autodesk DevCon in Munich May 28-29th
Rail Community
