Bug in Revit API
Bug in Revit API
sizy458
Bug in Revit API
sizy458
When I trace a rebar with method Rebar.CreateFromCurvesAndShape into wall which was traced by line by line since user interface, its work good.
I have exception when i trace rebar into wall which has traced by rectangle method since user interface.
An exception of type 'Autodesk.Revit.Exceptions.ArgumentException' occurred in RevitAPI.dll but was not handled in user code
Additional information: host is not a valid rebar host.
Parameter name: host occurred
 Cordial.
Sean_Page
Have you looked at the API reference for the error?
https://www.revitapidocs.com/2016/10ddc28e-a410-5f29-6fe9-d4b73f917c54.htm
Sean Page, AIA, NCARB, LEED AP
Senior Partner, Computational Designer, Architect
sizy458
yes i have always this error only on wall drawed by rectangle
