Bug in Create.NewDimension
ahmed.samy661993
ahmed.samy661993
I'm working on plugin that can create dimension from curved element to nearest (columns, str walls, arc walls, grids).
Problem : when i use => doc.Create.NewDimension(doc.ActiveView, unbound, references);
and one of two references is from element in linked files.
Error message : Invalid number of references.
Note : I tracked my code many times and I sure no mistake in it.
**I noticed when created dimension manually to grid in linked file (reference is RevitLinkInstance not grid)
any idea how to create dimension to element in linked file ?
caroline.gitonga
Hi @ahmed.samy661993,
Thank you for raising this question.
A similar question was raised sometimes back and a solution was found.
Kindly, check the link below see if it addresses your issue
https://forums.autodesk.com/t5/revit-api-forum/create-dimensions-for-familyinstance-in-linked-file/t...
Carol Gitonga, Developer Advocacy and Support, ADN Open
