[Bug] document.LoadFamily() breaks UI update
nice3point
Message 1 of 9
nice3point
When using the document.LoadFamily() method, there is a problem that freezes the UI update of both my plugin and the entire Revit ribbon. The problem occurs when my plugin has a Storyboard animation and when the family is updated during LoadFamily (for example, from version 2019 to 2023).
Tested Revit versions: 2021-2023
Before loading:
Updating:
After loading:
The revit ribbon is not responding, neither is my plugin. Temporary treatment by right-clicking anywhere or left-clicking on the properties panel.
Solution and family in attached files.
Replies (8)
Message 2 of 9
a.slutskij
I had the same problem in Revit 2022, but for now only on default Sample Architecture Project
Message 3 of 9
ricaun
I was not able to compile your solution in Visual Studio 2022, something with 'Duplicate AttributeUsage' related to the 'Microsoft.Toolkit.Mvvm.SourceGenerators.NullabilityAttributesGenerator'.
I create an example from scratch and looks like works fine.
After that, I add the 'ProgressRing' code on the WPF and something happens after loading the family, the UI break and stops updating or something.
Here is a quick video.
https://youtu.be/ZnaGXmanCrI
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 4 of 9
nice3point
@ricaunthanks for the video) https://github.com/dotnet/wpf/issues/6792#issuecomment-1183530305  this is a bug in the latest version of .Net 6, Microsoft hasn't fixed it yet, a workaround is to downgrade the Sdk version in global.json https://github.com/Nice3point/RevitTemplates/discussions/25
Message 5 of 9
ilya.sector.1
I had the same problem, UI breaks when there is animation during family update
Message 6 of 9
ricaun
Looks like is something related to the Storyboard and Animation in the WPF.
Message 7 of 9
Kennan.Chen
Loading a rfa file into a document using LoadFamily() freezes Revit UI - Autodesk Community - Revit ...
I ran into this problem years ago and you can refer to the above thread to get a workaround
Message 8 of 9
nice3point
The first time Balloon worked, all the others had no effect. It's a shame that for so many years the problem has not been raised or solved by Autodesk
Message 9 of 9
Kennan.Chen
It functions well to host the UI in a standalone WPF app that communicates with Revit process via IPC.
I use this workaround in production for years.
