BrowserOrganization - can we set this?
Message 1 of 1
I appologize for starting a new message regarding an existing one, but the existing one is erroneously (in my mind at least) marked solved. One serious drawback with Revit is just getting to the desired view. Half of that task is presenting the view browser options. A user in a shared project situation can save their own optimized Browser setup. A desired add-in would select that personal Browser setup on a project by project basis when the project is opened. That alone would mitigate much of the inherent drawback. All the bits and pieces required for such an add-in are in hand except the critical command to set the Project Browser to an existing named setup.  Can we set by program the Project Browser setup to an existing one and if so what are the basic concepts?  Thank you.
Replies (0)
