BIM 360 REST API to get Model Size?
mehdi.blanchard
mehdi.blanchard
I am using a macro to retrieve the model size.
For Revit Server files, I was able to use the REST API as follows:
ModelPath modelPath = doc.GetWorksharingCentralModelPath();
string server = modelPath.CentralServerPath; string fullPath = ModelPathUtils.ConvertModelPathToUserVisiblePath(modelPath);
string[] splitPath = fullPath.Split(new string[] {"/"}, StringSplitOptions.RemoveEmptyEntries); string restPath = string.Join("|", splitPath.Skip(2))); //removing protocol and server name WebRequest request = WebRequest.Create("http://" + server + "/RevitServerAdminRESTService" + version + "/AdminRESTService.svc/"+ restPath + "|/modelInfo" ); request.Method = "GET";
If I try to use a similar code on a BIM 360 file I get the error message below:
"The remote server returned an error: (400) Bad Request."
Note: the server (CentralServerPath) returns something like:
"https://modelxyz.skyscraper.autodesk.com:443/ModelService2015/ModelService.svc/basichttpbuffer"
So I am wondering:
  1. Is the REST API available on a BIM 360 model?
  2. If it is available how different is it to access it?
  3. If it is not available, is there another way to get the file size?
Note: I saw a Dynamo Script that gets the document GUID (doc.WorksharingCentralGUID), and search for the GUID.rvt in the local cache folder
eason.kangEDLV4
Autodesk Support
Autodesk Support
The "https://modelxyz.skyscraper.autodesk.com:443/ModelService2015/ModelService.svc/basichttpbuffer" is for Autodesk internal use only as I know, 3rd party users/customers cannot access it directly, you should use Forge APIs instead.
Here are some reference for getting started on the Forge:
https://fieldofviewblog.wordpress.com/forge/
Before getting the file size, you have to find the right item in the response of the Forge API GET projects/:project_id/folders/:folder_id/contents. You can iterate all file versions of items in the API response, then find matched projectGUID and ModelGUID in the "extension.data" attribute, like this:
   "type":"versions",
   "id":"urn:adsk.wipprod:fs.file:vf.abcd1234?version=1",
   "attributes":{
      "name":"fileName.rvt",
      "displayName":"fileName.rvt",
      "mimeType":"application/vnd.autodesk.r360",
      "storageSize":123456,                                         //!<<< physical size of the RVT file
      "fileType":"rvt",
      "extension":{
         "type":"versions:autodesk.bim360:C4RModel",
         "data":{
            "projectGuid":"48da72af-3aa6-4b76-866b-c11bb3d53883",  //!<<< Here
            "modelGuid":"e666fa30-9808-42f4-a05b-8cb8da576fe9",    //!<<< and here
Then you can get the physical size of the RVT file in bytes, see remark "//!<<< physical size of the RVT file" above. For more details, please see  https://forge.autodesk.com/blog/accessing-bim-360-design-models-revit
Note. To obtain both projectGUID and ModelGUID of the model you wanted to check the size, please call ModelPath#GetProjectGUID and ModelPath#GetModelGUID, see API docs here: http://www.revitapidocs.com/2018.1/f214cb44-8350-054e-821a-53571769f236.htm
Another way is checking the file stored in BIM360 OSS bucket. For using this approach, please refer my answer on a StackOverflow thread: https://stackoverflow.com/a/50520985/7745569
Hope it helps!
Cheers,
Eason Kang
Developer Advocate
Developer Advocacy & Support Service
Autodesk Platform Service (formerly Forge)
mehdi.blanchard
Thanks Eason,
I am not using Forge yet so I have just adapted the dynamo script to a C# script for now by locating the file in the cache folder.
if (fullPath.StartsWith("BIM 360")) {
  string folder = "C:\\Users\\" + Environment.UserName + "\\AppData\\Local\\Autodesk\\Revit\\Autodesk Revit " + app.VersionNumber + "\\CollaborationCache";
  string revitFile = doc.WorksharingCentralGUID.ToString() + ".rvt";
  string[] files = Directory.GetFiles(folder, revitFile, SearchOption.AllDirectories).Where(c => !c.Contains("CentralCache")).ToArray();
  if (files.Length > 0) {
    double length = (double)(new System.IO.FileInfo(files[0]).Length);
    int modelSize = Convert.ToInt32(Math.Round(length / BYTES_TO_MB));	// conversion from Bytes to MegaBytes
eason.kangEDLV4
Autodesk Support
Autodesk Support
Hi Mehdi,
It's nice to hear that you found your own solution without playing with the Forge.
Cheers,
Eason Kang
Developer Advocate
snhaMOSES
Hello.
I am new to C#
What classes and namespaces are necessary to make this code work?
When i put the line below into Macro editor i get an error concerning 'modelPath'
