02:15 PM
Hello Revit Community,
I work at Kalloc Studios on our flagship product Fuzor. We are converting our annotations files over to Bim Collaboration Format (.bcf) files. In the viewpoint.bcfv file every annotated component has a ifc guid. When syncing over a Revit (.rvt) file over to Fuzor I would like to port over the ifc guid to the BIM parameters using the Revit API. When generating the ifc guid parameter by calling GenerateParameter () with BuiltInParameter::IFC_GUID it shows that the ifc guid does not exists. Is this the correct way to get the ifc guid? If not, how would I proceed with getting the ifc Guid. Thank you in advanced.
Best Regards,
Scott Case
