Automatically OpenAndActivate a cloud model on Revit startup
Rockit_for_Revit
Rockit_for_Revit
I'm trying to automatically OpenAndActivate a cloud model. Given I need to access UIApplication I am doing it via UIControlledApplication.Idling event.
The command works fine when I open a local Revit model. However when I open a cloud model I am left with the following dialog 'Open Model' indefinitely and I have no option but to kill the Revit session.
I am opening the cloud model using the following:
Dim modelPath As ModelPath = ModelPathUtils.ConvertCloudGUIDsToCloudPath(If(region, ModelPathUtils.CloudRegionUS), ' Default to US region if not provided
    New Guid(projectGUID),
    New Guid(modelGUID)
Dim openOptions As New OpenOptions()
Dim objUIdocument As UIDocument = uiApp.OpenAndActivateDocument(modelPath, openOptions, False)
Any ideas?
ricaun
Maybe it's Idling, it's usually not safe to run long processes in there.
You could use ExternalEvent and verify if that works.
Some sample code like this:
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System;
namespace RevitAddin.Forum
    public class AppCloud : IExternalApplication
        public Result OnStartup(UIControlledApplication application)
            var region = ModelPathUtils.CloudRegionUS;
            var projectGuid = Guid.Parse("00000000-0000-0000-0000-000000000000");
            var modelGuid = Guid.Parse("00000000-0000-0000-0000-000000000000");
            // Create ExternalEvent and Raise to execute in the next idle cycle
            ExternalEvent.Create(new CloudOpenExternalEvent(region, projectGuid, modelGuid)).Raise();
            return Result.Succeeded;
        public Result OnShutdown(UIControlledApplication application)
    public class CloudOpenExternalEvent : IExternalEventHandler
        private string Region;
        private Guid ProjectGuid;
        private Guid ModelGuid;
        public CloudOpenExternalEvent(string region, Guid projectGuid, Guid modelGuid)
            Region = region;
            ProjectGuid = projectGuid;
            ModelGuid = modelGuid;
        public void Execute(UIApplication uiapp)
            try
                var modelPath = ModelPathUtils.ConvertCloudGUIDsToCloudPath(Region, ProjectGuid, ModelGuid);
                var options = new OpenOptions();
                uiapp.OpenAndActivateDocument(modelPath, options, false);
            catch (Exception ex)
                TaskDialog.Show(GetName(), ex.ToString());
        public string GetName()
            return nameof(CloudOpenExternalEvent);
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Rockit_for_Revit
Perfect thank you so much. I needed to seperate it out of OnStartup, however its essentally the same:
    Private Shared _externalEvent As ExternalEvent
    Public Sub CreateAndRaiseExternalEvent(filePath As String)
        _externalEvent = ExternalEvent.Create(New ExternalEvent(filePath))
        _externalEvent.Raise()
    End Sub
jeremy_tammik
OnStartup is useful to register event handlers and set up add-ins and stuff, but it is not the optimal time and place to start executing code. ApplicationInitialized is a later and probably more suitable choice:
Subscribe to this event to get notified after the Revit application has been initialized.
