Automatic space creation problem
WhiteSharx
WhiteSharx
Hello again!
This time my problem is as follows.
I wrote an addin that batch creates spaces on user selected floorplans in places that do not already contain them [spaces]. The algorithm there is to create spaces at all possible locations for the level and then delete those which overlap with existing ones.
It utilizes "Doc.NewSpaces2 method" which unfortunately will "regenerate the document even in manual regeneration mode" (see API ref.).
This causes unacceptable long execution time on my subject project file.
But there is also another method called NewSpace(Level level, Phase phase, UV point) which I hope will not regenerate the document at least after each creation unlike NewSpaces2. This method however must be supplied with a UV point at which the space is to be created.
Back to NewSpaces2 method.. if spaces are created manually via UI in Revit it happens rather fast and I guess its done with this method. Description states that NewSpaces2 creates spaces for every "circuit" (a closed loop I guess) of the given floor and I think it includes the procedure of finding them.
So my question is how one can obtain those closed loops that will serve as spaces boundaries?
Especially taking into account that space bounding geometry is in linked file and there might not be created rooms at every "cavity" there.
I tried to create a grid of UV points varying its scale (i.e. distance between points) and create a space at each of them but I believe its rather complicated and performance of this approach isn't much greater. So i need your help!
The code for the slow version is here
#region Namespaces
using System;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Collections.Generic;
using System.IO;
using System.Diagnostics;
using System.Reflection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
#endregion
namespace SpaceManager
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public static String strNewModelFullName = "";
        public static List<ViewPlan> AllFloorPlanViews = new List<ViewPlan>();
        public static List<int> SelectedFloorPlansIndicies = new List<int>();
        public static double Delta = 5; // 0.5=~150 mm, 5=~1.5m
        //public static double DeltaY = 0.5;
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            Autodesk.Revit.ApplicationServices.Application appsrv = commandData.Application.Application;
            Autodesk.Revit.Creation.Document docCreation = doc.Create;
            ElementCategoryFilter PhasesFilter = new ElementCategoryFilter(BuiltInCategory.OST_Phases);
            FilteredElementCollector AllPhasesFilterCollector = new FilteredElementCollector(doc);
            Phase Fase = new List<Phase>(AllPhasesFilterCollector.WherePasses(PhasesFilter).ToElements().Where(x=>x.Name=="New Construction").Cast<Phase>()).First();
            BuiltInCategory bic = BuiltInCategory.OST_Views;
            BuiltInParameter bip = BuiltInParameter.VIEW_TYPE;
            ParameterValueProvider provider = new ParameterValueProvider(new ElementId(bip));
            FilterStringRuleEvaluator evaluator = new FilterStringContains();
            FilterRule rule = new FilterStringRule(provider, evaluator, "Floor Plan", true);
            ElementParameterFilter name_filter = new ElementParameterFilter(rule);
            AllFloorPlanViews = new List<ViewPlan>(new FilteredElementCollector(doc)
                                                       .OfCategory(bic)
                                                       .WherePasses(name_filter)
                                                       .ToElements().Cast<ViewPlan>());
            List<Space> MEPSpaces = new List<Space>(new FilteredElementCollector(doc)
                                                       .OfCategory(BuiltInCategory.OST_MEPSpaces)
                                                       .ToElements().Cast<Space>());
            List<Level> Levels = new List<Level>(new FilteredElementCollector(doc)
                                                       .OfCategory(BuiltInCategory.OST_Levels)
                                                       .WhereElementIsNotElementType()
                                                       .ToElements().Cast<Level>());
            Dictionary<ElementId, List<Space>> LevelLandedSpacesDict = new Dictionary<ElementId, List<Space>>();
            Dictionary<ElementId, List<ElementId>> NewLevelLandedSpacesDict = new Dictionary<ElementId, List<ElementId>>();
            foreach (Space MEPSpace in MEPSpaces)
                if (!Levels.Contains(MEPSpace.Level))
                    Levels.Add(MEPSpace.Level);
                if (!LevelLandedSpacesDict.ContainsKey(MEPSpace.Level.Id))
                    LevelLandedSpacesDict.Add(MEPSpace.Level.Id, new List<Space>());
                LevelLandedSpacesDict[MEPSpace.Level.Id].Add(MEPSpace);
            ListBoxForm ListBoxFloors = new ListBoxForm();
            ListBoxFloors.ShowDialog();
            List<ElementId> ElsIDsToDel = new List <ElementId>();
            List<ElementId> NewSpIds = new List<ElementId>();
//SelectedFloorPlansIndicies now contains indicies for selected floorplans in AllFloorPlanViews List
            using (Transaction t = new Transaction(doc))
                t.Start("Creating Spaces");
                foreach (int FPind in SelectedFloorPlansIndicies)
                    Level L = AllFloorPlanViews[FPind].GenLevel;
                    if (!LevelLandedSpacesDict.ContainsKey(L.Id))
                        LevelLandedSpacesDict.Add(L.Id, new List<Space>());
                    NewLevelLandedSpacesDict.Add(L.Id, new List<ElementId>());
                    NewSpIds = docCreation.NewSpaces2(L, Fase, AllFloorPlanViews[FPind]).ToList<ElementId>();
                        NewLevelLandedSpacesDict[L.Id].AddRange(NewSpIds);
                        foreach (Space OldSp in LevelLandedSpacesDict[L.Id])
                            foreach (ElementId NewSp in NewLevelLandedSpacesDict[L.Id])
                                XYZ NewSpXYZ = (doc.GetElement(NewSp).Location as LocationPoint).Point;
                                //XYZ NewSpXYZ = NewSpPt.Point;
                                if (OldSp.IsPointInSpace(NewSpXYZ))
                                    ElsIDsToDel.Add(NewSp);
                                    NewLevelLandedSpacesDict[L.Id].Remove(NewSp);
                                    break;
                if (ElsIDsToDel.Count > 0)
                    doc.Delete(ElsIDsToDel);
                t.Commit();
            return Result.Succeeded;
So I looked into this problem a little more last night because it intrigued me. I didn't come up with a perfect solution but this could potentially work:
1. Use PlanTopology pt = new PlanTopology(level) to get the plan topology of the specified level
2. From there you can get the circuits you were talking about by doing circuits = pt.Circuits
3. Now you cannot specifically create spaces using those circuits because there is no method "NewSpace(circuit)" but you can create rooms that way. So I suggest using another transaction prior to your space creation one that creates new Rooms in the empty circuits (you can check if a circuit is empty by calling circuit.IsRoomLocated; you create a new room in an empty circuit via NewRoom(room, circuit)) and then add the location of that room via room.Location to some list.
4. Rollback the transaction where you created new rooms
5. Do your transaction to create new rooms using the locations that you just found
It's not perfect but you can at least see if you get increased performance from it. It's unfortunate that there is no new room functions that accepts a plan circuit as a parameter.
WhiteSharx
mapspacenamer, thank you for the advice! Sorry for late answer.
I will try to move this way.
There is a hope that solution is easier than you suppose, because PlanCircuit class even has the very needed method .GetPointInside!
