Autodesk.Revit.Utility in Revit 2019
Dale.Bartlett
Dale.Bartlett
This is probably late to the 2019 party, but can someone point me to the replacement for Autodesk.Revit.Utility in Revit 2019? I have done several searches and API help. This is a shortcut. Many thanks. Dale
______________
Yes, I'm Satoshi.
zhong_wu
Autodesk Support
Autodesk Support
The API classes under Autodesk.Revit.Utility namespace have been moved to Autodesk.Revit.DB.Visual since 2018, can you check the APIs there to see if that's you are looking for? Here is the blog and What' New in API of 2018 for your reference:
http://thebuildingcoder.typepad.com/blog/2017/04/whats-new-in-the-revit-2018-api.html
http://www.revitapidocs.com/2018/news
Let me know if that's what you want.
John Wu
Developer Technical Services
Autodesk Developer Network
Dale.Bartlett
Thank you. I had managed to resolve it and should have posted earlier. I appreciate your response, always helpful. Dale
______________
Yes, I'm Satoshi.
