Autodesk Revit - Shared Parameters 2015 -> 2016
I have an error when using my plugin with Revit 2016.
Here's the error
Méthode introuvable : 'Autodesk.Revit.DB.Definition Autodesk.Revit.DB.Definitions.Create(System.String, Autodesk.Revit.DB.ParameterType)'.
I've seen that the 2016 API delete the Autodesk.Revit.DB.Definitions.Create function, but I can't find what can I use instead.
Thanks in advance,
Revitalizer
RevitAPI.chm says that Create method needs an "ExternalDefinitionCreationOptions" object.
There are 24 matching lines when searching that name in the SDK.
See also:
http://forums.autodesk.com/t5/revit-api/rtfm-and-using-the-search-function/td-p/5822690
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
jeremytammik
I agree with Revitaliser!
RTFM indeed.
Here is more:
http://thebuildingcoder.typepad.com/blog/2015/06/cnc-direct-export-wall-parts-to-dxf-and-sat.html#20...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
tdivittis
Why  bother replying?  If the OP was an expert, with access to the information at your fingertips, they wouldn't need to post questions here.
jeremytammik
Dear Tdivittis,
Why have you posted this comment?
Both replies above contain valuable links to important relevant information, accessible at everybody's fingertips.
As far as can be told, they helped resolve the issue
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
tdivittis
"RTFM indeed" caught my eye.  If I misunderstood, I sincerely apologize.
I'm a 'dirt guy' (civil), trying to help someone with some code for updating shared parameters using data compiled from other sources, and was a bit tired/frustrated when I wrote that comment, so it is quite possible I misread it.
