Autodesk Nuget Packages for Revit dlls?
BKSpurgeon
BKSpurgeon
Hi there
Was just working through my first "hello world" revit api.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_...
In the Add Reference dialog box, click the Browse tab. Locate the folder where Revit is installed and click the RevitAPI.dll. For example, the installed folder location is usually C:\Program Files\Autodesk\Revit 2018\RevitAPI.dll.
I prefer not doing this manually.
This is a pain, especially if I should transfer the project to someone else with different file paths.
Is there not a nuget package that AUTODESK maintains for this purpose? Was curious how everyone else manages this?
Speed_CAD
Hi BKSpurgeon,
I like to always start from scratch, but to avoid adding references, the IExternalApplication and/or IExternalCommand interfaces and the .addin file manually, I generated a template in Visual Studio. So when I create a new project I choose my own template.
For example:
Mauricio Jorquera
jeremy_tammik
There are a large number of Revit API related NuGet packages:
166, in fact. Unfortunately, afaik, none of them are officially maintained by Autodesk. I asked the development team about this for you...
