AutoCAD crashes when starting from Revit API
I have a simple Revit addin setup where the users selects a linked dwg and the addins opens tha dwg in autocad to edit. However whenever I start AutoCAD from within the Revit addin I get the error "Unhandled Exception C0000005 (Access Violation Reading 0x0008) at address CADE4A58h".
Even this simple code gives me the error:
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
namespace ClassLibrary1
    [TransactionAttribute(TransactionMode.Manual), RegenerationAttribute(RegenerationOption.Manual)]
    public class Class1 : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            System.Diagnostics.Process.Start(@"C:\test.dwg");
            return Result.Succeeded;
Just to be clear. If I double click the DWG file in windows explorer the file opens just fine without error. If I create a console application outside of the Revit API with just the process start command, the DWG opens just fine. IE
using System;
using System.Diagnostics;
namespace startautocad
    class Program
        static void Main(string[] args)
Any idea why I get the error in the Revit addin?
jeremytammik
Dear Mwilson1,
Thank you for the interesting question.
No idea whatsoever.
However, you could try an alternative approach:
Use the AutoCAD COM Interop functionality to start up AutoCAD, load the DWG, and either display or hide the user interface, as you prefer:
http://thebuildingcoder.typepad.com/blog/2013/04/launching-autocad-within-a-revit-add-in.html
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
stever66
I really don't have a clue, but lots of possibilities come to mind:
windows associtivity, autocad license, autocad startup arguments, user logon, network issue.
Unless you have already tried this, why not try substituting a more basic program instead of autocad and see if that works.  Like opening a simple text document.
Also, you might try some of the overloads for this command, listed here:
https://msdn.microsoft.com/en-us/library/system.diagnostics.process.start(v=vs.110).aspx
For example, you might try specifying the name of the program to run.
Thank you for the suggestion. I was able to run
Process.Start(@"c:\test.txt");
Process.Start(@"c:\test.pdf");
Successfully. The text file opened in notepad and the pdf in Bluebeam.
I don't know if it helps, but when I open a DWG with the code above, I'm able to work in the drawing for a second or two. Usually just enough to zoom around, before it crashes. However if I do nothing it still crashes.
Also as a note, when I open a DWG in AutoCAD with the Visual Studio debugger running on the Revit addin, AutoCAD crashes completly without an error message. It's only if I run outside of visual studio do I get the error above.
I'm trying to make this addin as generic as possible for the office, because we have all different flavors of AutoCAD installed, between 2010 and 2016.
stever66
For what its worth, I can put:
in a Sharp Develop Macro (inside Revit), and it starts autocad and opens the file just fine.   It takes it longer than if I just click the Autocad icon itself, but it does the same thing if I just double click a file in explorer.
Jeremy's suggestion might be your best bet.
