Associate railing category a shared parameter from api
I created a routine to create a shared parameter (param1), I need to associate this parameter to the railing category but does not show the category associated with the parameter, I bear this code:
Autodesk.Revit.ApplicationServices.Application app = (Autodesk.Revit.ApplicationServices.Application)sender;
Document doc = e.Document;
DefinitionFile sharedParametersFile = OpenSharedParamFile(app);
DefinitionGroup eBIMgroup = OpenGroup(sharedParametersFile);
Definition definition = OpenDefinition(eBIMgroup);
Category Railings = doc.Settings.Categories.get_Item(BuiltInCategory.OST_Railings)
ategorySet categoryset = app.Create.NewCategorySet();
categoryset.Insert(Railings);
Transaction tran = new Transaction(doc, "Parametro");
tran.Start();
Autodesk.Revit.DB.Binding binding = app.Create.NewInstanceBinding(categoryset);
doc.ParameterBindings.Insert(definition, binding, BuiltInParameterGroup.PG_TEXT);
tran.Commit();
when I write code "BuiltInCategory." Several options appear which is correct?
Tranks, I hope you can help me!
rosalesduquej
Hi Marcos,
I'm not too familiar with the Railings from the API, But I found a post by Jeremy, Have you seen it before? I see he uses OST_StairsRailing as his BuiltInCategory After he Investigated with the RevitLookup Tool, Have you tried that?
http://thebuildingcoder.typepad.com/blog/2011/07/retrieve-railing-elements.html
Hope it helps,
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
rosalesduquej:
I not visited thebuildingcoder.com for not view this post I saw the post on page thebuildingcoder.com you indicate. in this post it is what I wanted.
Category Railings = doc.Settings.Categories.get_Item(BuiltInCategory.OST_StairsRailing);
Thanks for help me
rosalesduquej
Hi Marcos,
You are very welcome, Glad it worked for you.
Cheers,
Jaime Rosales D.
