AssemblyViewUtils.CreateDetailSection - isAssigned param disorganize the viewport layout
mgutierrezBM9E9
mgutierrezBM9E9
I plan to place 2 assembly viewports at the top left corner of a titleblock.
When using the following code to create 1 viewport, everything works fine:
var sectionView = AssemblyViewUtils.CreateDetailSection(TicketPopulatorCommand.doc, assemblyId, anchorView.SectionOrientation
?? AssemblyDetailViewOrientation.ElevationTop, anchorViewTemplate.Id, true);
FamilyInstance titleBlock = new FilteredElementCollector(TicketPopulatorCommand.doc)
.OfClass(typeof(FamilyInstance))
.OfCategory(BuiltInCategory.OST_TitleBlocks)
.WhereElementIsNotElementType()
.Where(x => x.OwnerViewId == viewSheet.Id)
.Cast<FamilyInstance>()
.FirstOrDefault();
if (titleBlock == null) throw new Exception("No title block found on the sheet.");
BoundingBoxXYZ titleBlockBox = titleBlock.get_BoundingBox(viewSheet);
XYZ titleBlockMin = titleBlockBox.Min; // Bottom-left of title block
XYZ titleBlockMax = titleBlockBox.Max; // Top-right of title block
XYZ location = new XYZ(titleBlockMin.X, titleBlockMax.Y,0);
Viewport viewport = Viewport.Create(TicketPopulatorCommand.doc, viewSheet.Id, sectionView .Id, location);
However, when looping on multiple views there is an offset that gets added to the next view port (in the sample below the viewport from above was passed in the second loop, therefore an offset has been added to that viewport).
By the way, on every loop the min and max value of the title block is the same:
{(-3.328760717, -4.658490202, 0.000000000)}
{(-1.754686650, -3.639971685, 0.000000000)}
I have no clue where the offset is coming from.
Another examples when placing 3 viewports!
mgutierrezBM9E9
Can someone from the autodesk dev team take a look into this. Apparently the api does not allow to palce multiple viewports at the same location. Can you confirm this please?
Moustafa_K
can you show us how are you looping?
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
mgutierrezBM9E9
I'm not even looping, I'm just creating the assembly sheet:
FamilySymbol titleBlock = new FilteredElementCollector(doc).OfClass(typeof(FamilySymbol))
    .OfCategory(BuiltInCategory.OST_TitleBlocks).Cast<FamilySymbol>()
    .FirstOrDefault(tb => tb.Name.Equals(ticketTemplate.Titleblockname, StringComparison.OrdinalIgnoreCase));
if (titleBlock == null) return MolinErrors.Shared.ThrowError($"Titleblock not found: {ticketTemplate.Titleblockname}",
    tg: tg, tr: tr);
ViewSheet viewsheet = AssemblyViewUtils.CreateSheet(doc, assembly.Id, titleBlock.Id);
Then, I'm querying the titleblock placed on that sheet:
FamilyInstance titleBlockInstance = new FilteredElementCollector(TicketPopulatorCommand.doc)
    .Where(x => x.OwnerViewId == viewsheet.Id)
    .FirstOrDefault();
if (titleBlockInstance == null) throw new Exception("No title block found on the sheet.");
then I'm picking the top left corner of the titleblock:
                                BoundingBoxXYZ titleBlockBox = titleBlock.get_BoundingBox(viewsheet);
                                XYZ location = new XYZ(titleBlockMin.X, titleBlockMax.Y, titleBlockMax.Z);
Finally I'm creating views and placing them onto the sheet:
ElementId mainViewId = TicketPopulatorApp.Shared.CreateView(ticketTemplate.AnchorViews.MainView, assembly.Id);
Viewport viewport = Viewport.Create(TicketPopulatorCommand.doc, viewsheet.Id, mainViewId, location);
ElementId bottomViewId = TicketPopulatorApp.Shared.CreateView(ticketTemplate.AnchorViews.BottomView, assembly.Id);
Viewport bottomVP = Viewport.Create(TicketPopulatorCommand.doc, viewsheet.Id, bottomViewId, location);
This is my CreateView method:
public ElementId CreateView(AnchorView anchorView, ElementId assemblyId) {
    if (TicketPopulatorCommand.doc == null) throw new Exception("Document can not be null");
    View anchorViewTemplate = new FilteredElementCollector(TicketPopulatorCommand.doc)
        .OfClass(typeof(View)).Cast<View>().FirstOrDefault(v =>
        v.IsTemplate && v.Name == anchorView.ViewTemplateName);
    if (anchorViewTemplate == null) throw new Exception($"Template not found: {anchorView.ViewTemplateName}");
    ElementId anchorViewId = ElementId.InvalidElementId;
    switch (anchorView.IsSection)
        case true:
            anchorViewId = sectionView.Id;
            break;
        case false:
            var view3d = AssemblyViewUtils.Create3DOrthographic(TicketPopulatorCommand.doc, assemblyId, anchorViewTemplate.Id, true);
            anchorViewId = view3d.Id;
            break;
    return anchorViewId;
mgutierrezBM9E9
it's crazy, but changing the last parameter from true to false fixed the issue!
?? AssemblyDetailViewOrientation.ElevationTop, anchorViewTemplate.Id, false);
The documentation says the following description:
isAssigned Type: SystemBoolean
If true, the template will be assigned; if false, the template will be applied.
Does someone mind elaborating more on that? I'm still confused how the true value affect the layout of the views.
