assembly version mismatch when using OpenAIClient
Im trying to get response from openAI by sending prompt in class library, I have downloaded azure.AI.OpenAI package then Im unable to create client but same code is working fine when Im using winforms project template without any error
here is the code:
private async void button1_Click(object sender, EventArgs e)
OpenAIClient client = new OpenAIClient(new Uri( "my uri"), new AzureKeyCredential("my key"));
var chatCompletionsOptions = new ChatCompletionsOptions()
DeploymentName = "my deployment name", //This must match the custom deployment name you chose for your model
Messages =
new ChatRequestSystemMessage("You are a helpful assistant."),
new ChatRequestUserMessage("please translate 'BUILDING FINAL DETAILS TO BE CONFIRMED BY A SUPPLIER IN THE NEXT PROJECT PHASE.' to spanish."),
new ChatRequestAssistantMessage(""),
MaxTokens = 100
Response<ChatCompletions> response = client.GetChatCompletions(chatCompletionsOptions);
Console.WriteLine(response.Value.Choices[0].Message.Content.Split('"')[1]);
Console.WriteLine();
