Area Intersection
Area Intersection
Tripler123
Area Intersection
Tripler123
Intersection area of Beam and Column
Dear guys,
i want to calculate intersection area of Beam and Column. Is this is possible?
 For more details please see attached image.
Thanks ,
if any one have any idea please share with me.
jeremytammik
Yes, sure.
You can query the elements for their geometry, retrieve the faces from that, and call the Face.Intersect method:
http://www.revitapidocs.com/2018/91f650a2-bb95-650b-7c00-d431fa613753.htm
Note that it works on the unbounded faces, not the bounded ones, as we recently discussed and discovered:
https://forums.autodesk.com/t5/revit-api-forum/surprising-results-from-face-intersect-face-method/m-...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
Oh.
Re-reading your question, I not that you are not asking for the intersection curve between two non-planar faces, but the intersection area between to coplanar ones.
Afaik, the Revit API does not provide any support for that.
For that, you can resort to a stand-alone 2D Boolean operation library instead:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.2
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Tripler123
thank you very much for your reply. Checking to see what can come out.
