Apply multiple text styles in one textnote programmatically
jnoordzij
jnoordzij
I want to know if it is possible to change the text style for a subset of characters in a Revit textnote programmatically. Someone showed me below screenshot in which they were able to achieve this, I think using some special plugin. I want to know if it is possible to do this through the Revit API. If so, could you point me towards the API docs where this is described?
Example : lets say I have textnote containing the text 'Text 1 / Text 2'. I want to be able to assign a different textstyle to the 'Text 2' substring.
Your help is much appreciated
jeremy_tammik
I asked Gemini for you. Please check whether this helps:
jnoordzij
Hi Jeremy! Great to see you're still going strong.
I'm not super enthusiastic about Gemini's suggestion to create separate Textboxes positioned side by side to create the appearance of a single, formatted Textbox. I want to avoid separate textboxes.
However it did point me towards finding the TextNote.GetFormattedText / SetFormattedText methods. The FormattedText class seems to offer what I need !
Thanks for your help. Nice tool this Gemini 🙂
