Application Hang after using DockablePane (Top level window is idle)
jw.vanasselt
Message 1 of 13
jw.vanasselt
Hi all,
One of the users has a problem with using a dockable pane application. (Library window)
The Dockable Pane is a WPF Page with xml data.
After MouseDoubleClick the an IExternalEventHandler Raise and in that event there a prompt to place a familysymbol.
Any ideas?
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Application Hang" />
  <EventID Qualifiers="0">1002</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>101</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2024-03-14T11:14:34.1058526Z" />
  <EventRecordID>190754</EventRecordID>
  <Correlation />
  <Execution ProcessID="0" ThreadID="0" />
  <Channel>Application</Channel>
  <Computer>[ComputerName]</Computer>
  <Security />
  </System>
- <EventData>
  <Data>Revit.exe</Data>
  <Data>23.1.30.97</Data>
  <Data>277c</Data>
  <Data>01da75ffec5ff3c6</Data>
  <Data>4294967295</Data>
  <Data>C:\Program Files\Autodesk\Revit 2023\Revit.exe</Data>
  <Data>cf05ffb2-a754-4417-b9c5-afa3235601e1</Data>
  <Data />
  <Data />
  <Data>Top level window is idle</Data>
  <Binary>54006F00700020006C006500760065006C002000770069006E0064006F0077002000690073002000690064006C00650000000000</Binary>
  </EventData>
  </Event>
 This topic is a little bit related to this topic:
Solved: Re: Close Dockable Window EventArgs - Autodesk Community - Revit Products
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.UI;
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.IO;
using System.Linq;
using System.Windows;
using System.Windows.Media;
using System.Xml;
namespace VDS
    class RevitPane : IDockablePaneProvider
        // GUID voor DockablePane
        public static readonly Guid Id = new Guid("----");
        //Variable die toegewezen wordt in app
        public static RevitPane Default { get; private set; }
        public RevitPane(IExternalEventHandler_Bibliotheek eventHandler, ExternalEvent externalEvent)
            EventHandler = eventHandler;
            ExternalEvent = externalEvent;
        public IExternalEventHandler_Bibliotheek EventHandler { get; }
        public ExternalEvent ExternalEvent { get; }
        #region Registratie van panel positie
        public static void Register(UIControlledApplication app)
            var eventHandler = new IExternalEventHandler_Bibliotheek();
            var externalEvent = ExternalEvent.Create(eventHandler);
            Default = new RevitPane(eventHandler, externalEvent);
            var dockablePaneId = new DockablePaneId(Id);
            app.RegisterDockablePane(dockablePaneId, "Bibliotheek", Default);
        #endregion
        #region Toggle panel aan/uit
        public static void Toggle(UIApplication app)
            var dockablePane = app.GetDockablePane(dockablePaneId);
            if (dockablePane.IsShown())
                dockablePane.Hide();
            else
                dockablePane.Show();
        public void SetupDockablePane(DockablePaneProviderData data)
            // wpf object with pane's interface
            data.FrameworkElement = new Viewer();
            // initial state position
            data.InitialState = new DockablePaneState
                DockPosition = DockPosition.Right
        #endregion
Void that raised the event
private void LibraryListView_MouseDoubleClick(object sender, MouseButtonEventArgs e)
    List<FileData> selectedItemsList = new List<FileData>();
    foreach (var selectedItem in libraryListView.SelectedItems)
        if (selectedItem is FileData fileData)
            selectedItemsList.Add(fileData);
    RevitPane.Default.EventHandler.selectedFileData = selectedItemsList;
    RevitPane.Default.ExternalEvent.Raise();
Replies (12)
Message 2 of 13
ricaun
Never heard about his Application Hang issue.
One thing that is not clear is what the IExternalEventHandler_Bibliotheek does, you mention something to place a family symbol?
Maybe a sample code to reproduce would help.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 3 of 13
jw.vanasselt
Forgot that one to copy.
using Autodesk.Revit.Attributes;
using Autodesk.Revit.Creation;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI.Events;
using System;
using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Controls;
using System.Xaml;
using static VDS.VDS_standaard_definities;
using Document = Autodesk.Revit.DB.Document;
namespace VDS
    [Transaction(TransactionMode.Manual)]
    public class IExternalEventHandler_Bibliotheek : IExternalEventHandler
        internal List<FileData> selectedFileData = new List<FileData>();
        //gegevens voor log
        private string fam_path = string.Empty;
        private string famtype = string.Empty;
        private string versienummer = string.Empty;
        public void Execute(UIApplication uiapp)
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            FamilySymbol fs = null;
            Autodesk.Revit.ApplicationServices.Application app = doc.Application;
            versienummer = app.VersionNumber;
            using (Transaction trans = new Transaction(doc, "Family inladen"))
                try
                    trans.Start();
                    // Filedatas doorlopen
                    foreach (FileData file in selectedFileData)
                        //FamilyPath en type bepalen
                        string familyPath = file.FamilyPath;
                        string familyTypeName = file.FamilyTypeName;
                        string familyName= GetFileNameWithoutExtension(familyPath);
                        fam_path = familyPath;
                        famtype = familyTypeName;
                        // FamilySymbol ophalen vanuit familyName en familytype name
                        fs = new FilteredElementCollector(doc)
                            .OfClass(typeof(FamilySymbol))
                            .Cast<FamilySymbol>()
                            .FirstOrDefault(x => x.FamilyName == familyName && x.Name == familyTypeName);
                        // Als niet aanwezig is dan inladen
                        if (fs == null)
                            CustomFamilyLoadOptions load_options = new CustomFamilyLoadOptions();
                            if(doc.LoadFamilySymbol(familyPath, familyTypeName, load_options, out fs))
                                continue;
                            else
                                TaskDialog.Show("Error", "Er gaat iets mis met het inladen van de family.");
                    trans.Commit();
                catch (Exception ex)
                    TaskDialog.Show("Waarschuwing", $"{ex.Message}\n\n{ex.StackTrace}");
                    trans.Commit();
            // Event trigger aanmaken voor plaatsen component
            app.DocumentChanged += new EventHandler<DocumentChangedEventArgs>(OnDocumentChanged);
            // Family plaatsen en aan de muis hangen
            try
                // Plaatsen familys
                uidoc.PromptForFamilyInstancePlacement(fs);
            catch
            // Event trigger sluiten voor performance
            app.DocumentChanged -= new EventHandler<DocumentChangedEventArgs>(OnDocumentChanged);
            //leegmaken van gegevens
        void OnDocumentChanged(object sender, DocumentChangedEventArgs e)
            if (e.GetTransactionNames().Contains("Component"))
                // Bibliotheek log vullen
                VDS_Log vDS_Log = new VDS_Log();
                vDS_Log.Bibliotheek_log(fam_path, famtype, versienummer);
        static string GetFileNameWithoutExtension(string path)
            // Gebruik de Path-klasse om het bestandsnaamcomponent uit het pad te halen
            string fileName = Path.GetFileName(path);
            // Vervolgens haal je de extensie eraf
            string fileNameWithoutExtension = Path.GetFileNameWithoutExtension(fileName);
            // Split het pad op de backslash ('\') en neem het laatste deel
            string[] pathParts = path.Split('\\');
            string lastPart = pathParts[pathParts.Length - 1];
            // Verwijder het laatste deel uit de bestandsnaam
            fileNameWithoutExtension = fileNameWithoutExtension.Replace(lastPart, "");
            return fileNameWithoutExtension.Trim('\\');
        public string GetName()
            return "Bibliotheek eventhandler";
Message 4 of 13
jw.vanasselt
I see that I use the Commit() inside the catch, should that be the problem?
Message 5 of 13
ricaun
The code looks right, I didn't spot anything strange.
The `Commit()` caught my eye, and looks fine, I usually put Rollback in there.
One thing I didn't get is, where that XML data for the error is coming from?
The 'Application hang' is like Revit freezes and eventually shows a fatal error like this?
And what else do you have inside the page `Viewer`, if some exceptions happen in some events in the WPF, the Revit application usually crashes.
A button with this click event gonna make Revit unhappy.
private void Button_Click(object sender, System.Windows.RoutedEventArgs e)
    throw new Exception("Fatal Error!");
Message 6 of 13
jw.vanasselt
 No, there is no crash,  the Application hang after using the tool, after 2/3 minutes you can use revit again. When I use the library again the Application is hanging again.
The viewer is reading xml data and views products with a image and product data
There is a search option in it
Message 7 of 13
ricaun
Now I get it what the Application hang means, your code is doing a big process and Revit is not responding until the process ends.
How big is the selectedFileData list?
If you selectedFileData is big and you have many symbols in the document, pretty sure your code is waiting time checking if the symbol exist in the document.
Message 8 of 13
jw.vanasselt
The selectedFileData is a single (binding) element with a path to the place where the family is located and the specific type. After that I check if the family is loaded, of he isnt i load it into the project. Otherwise I use the one in the project
Message 9 of 13
jw.vanasselt
Any suggestions how to log/debug to find the problem?
Message 10 of 13
ricaun
If it is a single file why `selectedFileData` is a list?
I suppose the FilteredElementCollector could be running multiple times that, but it could be other stuff.
The best way to debug is to create some IExternalCommand and test it there.
Message 11 of 13
jw.vanasselt
Good question, I guess it's not necessary.
I will review my code Log everything to see what is going wrong.
Message 12 of 13
ctm_mka
Curious about the use of "MouseButtonEventArgs". The event handler does not seem to specifically be looking for a double click, perhaps it is firing twice, thus the hang?
Message 13 of 13
jw.vanasselt
The handler is Raising the EventHandler.
