AppearanceAssetId not available
I am trying to create a new material and set it appearance properties (in particular it's color).
I have tried to find and existing appearance asset and use it to create my own copy. However, when I loop over all materials using the following code:
            var materials = new FilteredElementCollector(modelDocument)
                .OfClass(typeof(Material))
                .ToElements()
                .Cast < Material > ().ToList();
and check the AppearanceAssetId property, I see that for all materials it's set to -1 (including all the default materials).
How can I retrieve a valid asset to create my own instance?
franciscopossetto
Hey,
I tested your code on the Revit sample house and it worked. I can read the AppearanceAssetId:
Then I tried on an empty project, without templates. Materials were created, but they all had -1 as ApparenceAssetId as your case. For some reason, the Generic AppearanceAsset applied has this Id. If you add a new one from the Library, then it has another id.
I would check how many appearanceAssetElements you have on the model.
ICollection<Element> appearanceAssetElements = new FilteredElementCollector(doc).OfClass(typeof(Autodesk.Revit.DB.AppearanceAssetElement)).ToElements();
And then, get the one you need:
string appearanceAssetElementId= "144211";
ElementId appearanceAssetElement = new FilteredElementCollector(doc).OfClass(typeof(AppearanceAssetElement)).ToElementIds().Where(a => a.ToString().Equals(appearanceAssetElementId)).FirstOrDefault();
I hope it helps.
Kind regards.
Github:
https://github.com/franpossetto
