API vs Manual
API vs Manual
myrwen_juntereal6EWNX
API vs Manual
I have a floors that are created via API, for some reason i cannot get its boundary curves. The image on the left returns 0 curveloop while the image on the right (manually created) works fine. Please see below code and image for reference.
private static List<CurveLoop> GetFloorBoundaryLoops(Floor floor)
    List<CurveLoop> curveLoops = new List<CurveLoop>();
    Document doc = floor.Document;
    ElementId elementId = new ElementId(floor.Id.IntegerValue - 1);
    List<Curve> curves = new List<Curve>();
    CurveLoop curveLoop;
    if (doc.GetElement(elementId) is Sketch element)
        int size = element.Profile.Size;
        for (int i = 0; i < size; i++)
            CurveArray item = element.Profile.get_Item(i);
            if (item != null)
                foreach (Curve curve in item)
                    curves.Add(curve);
            curveLoop = new CurveLoop();
            for (int j = 0; j <= curves.Count - 1; j++)
                curveLoop.Append(curves[j].Clone());
            curves.Clear();
            curveLoops.Add(curveLoop);
    return curveLoops;
Moustafa_K
Well, it is unclear why you are expecting the right sketch element when you do this statement
since Revit 2022 there is already an element ID for sketch as a member of the floor. so you can safely use it, then you can retrieve the profile as CurveArray... see more detail over here
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Moustafa_K
just wanted to add... you can boil plate your code to just two lines
var floorSegments = sketch.Profile.Cast<CurveArray>().First().Cast<Curve>().ToList();
CurveLoop cloop = CurveLoop.Create(floorSegments);
just to note this will skip the holes if any inside your floor
Moustafa Khalil
unfortunately, our current project is still in Revit 2021, cannot upgrade yet
Moustafa_K
oh.. ok, then a tricky way is to get it from the editor, however, ensure the shape of the floor is not modified, other wise you need to reset it first, then roll back the transaction
see this example
Trans.Start();
floor.SlabShapeEditor.ResetSlabShape();
Doc.Regenerate();
CurveLoop cloop = new CurveLoop();
foreach (SlabShapeCrease creaseedCurve in floor.SlabShapeEditor.SlabShapeCreases)
    cloop.Append(creaseedCurve.Curve);
Trans.RollBack();
Moustafa Khalil
TripleM-Dev.net
Hi @myrwen_juntereal6EWNX,
I use a Extension to get the sketch of a Ceiling in Revit 2017 to 2024.
For Revit 2022 use the SketchId property
For before Revit 2022 use the GetDependentElements Method and as filter use:
ElementClassFilter filter = new ElementClassFilter(typeof(Sketch));
This should also work for floors.
- Michel
See image below of the posted document (updated to R2022, don't have R2021 installed), but as seen the Id of the sketch is identical between the 2 options:
(and it's Id is not 1 less then the Id of the floor itself, floor id: 2631, sketch 2622, maybe if created by UI by coincidence)
