API equivalent of Schedule Conditional Formatting dialog
ser
ser
I want to automatically configure Conditional Formatting in a Sheet Schedule.
Manually in the UI this works:
Schedule Properties → Formatting → Conditional Formatting
Rule:
Field: Highlight sheet in schedule (Yes/No parameter on Sheets)
Test: Equal To
Value: Yes
Background color: chosen color
When the parameter is Yes, the entire row becomes highlighted.
I want to automatically set up this rule for a schedule so users do not need to configure it manually.
Questions:
1. Is it possible to create this Schedule Conditional Formatting rule automatically?
2. Can the parameter used for the rule remain hidden in the schedule?
Revit version: 2026
Schedule type: Sheet Schedule
Screenshot of the manual setup attached.
sragan
I don't know if that's possible in the API.  However, I do know it's possible to apply a template to a schedule via the API.
Would a possible workaround be to include a schedule template in the project, and then apply this template to the schedule you want to have the conditional formatting?
Assuming a schedule template stores the conditional formatting.....
