Annotation tags deleted when moving components!
Message 1 of 12
Why do associated annotation tags get deleted when moving a component using the move command, but not when moved using arrow keys or align command?! very annoying Autodesk - sort this out please
Move command.png.
Replies (11)
Message 2 of 12
kimberly_fuhrman-jones
Hi, @Anonymous ...this sounds like a bug. I will run it past the team. I may need to move this to the Revit forum so it gets escalated there. I'll keep you posted!
Kimberly Fuhrman-Jones
Revit Community Manager
Message 3 of 12
ok great, note this is in Revit 2021.1.1
Message 4 of 12
@Anonymous  Thank you!
Message 5 of 12
@Anonymous  Confirmed that this is a bug. I will move this post to the Revit API forum and file a problem report for you. Please let me know if I can be of further assistance!
-Kimberly
Message 6 of 12
I have found the solution, I had ‘disjoin’ ticked when using move command!
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 7 of 12
GaryOrrMBI
This has actually been an ongoing issue for years, as far back as I can remember.
As the OP ended up finding the setting of disjoin is usually the cause, but not always...
Of course, not all entities have the disjoin option, so Revit uses the last used value (ie, if you intentionally moved an entity using the disjoin option then the next entity will automatically use the disjoin option even if that option is not available for that entity) which makes it impossible to turn it off (set it back to join) while moving those entities. You have to go back and move something that does have the option and toggle the disjoin off, then the entity that doesn't have the option will move with fewer issues.
It isn't just tags either.
There is no reason that tags, dimensions, etc should be deleted just because you use the move command for precision over dragging things around willy-nilly, yet they are. Often. There is also no reason for such annotation to be deleted regardless of the join/disjoin option, yet they are. Often.
It almost acts if Revit doesn't "Move" an entity when using the move command but, rather, creates a new entity and removes the old one, therefore previous tags and dimensions don't apply, which, of course, isn't the case, but it is what the behavior seems to indicate.
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Message 8 of 12
cam-nav
I would push to have this bug fixed or at least have another option so we can keep our associated tags/text. In the construction field, we move content after annotating. when Revit deletes the text/tags we run into quality control issues. Typically, tags are on multiple sheets, making this bug a disastrous task because we are very expensive labor.
Message 9 of 12
jskinnerAU9DM
FYI This is still an issue in Revit 2022.
Message 10 of 12
willkperkins
Still an issue in 2022.1
Message 11 of 12
brandonD853N
Still an issue in 2024...
Message 12 of 12
tomekpracowniagandalf_pl
Observer
Observer
Still an issue in 2025
