Annotation Angle
Annotation Angle
Annotation Angle
How do I create a angular dimension via api similar to Annotate->Angular.
Thanks & Regards
Sanjay Pandey
Charles.Piro
you can use this :
doucment.FamilyCreate.NewAngularDimension(View view,Arc arc,Reference firstRef,Reference SecondRef);
You have an example in SDK Sample -> Project "CreateTruss".
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
Sorry If I was not clear in my query. But I am not creating the angular annotation in family document.
What I want is the angle between two objects say for example pipe and a sprinkler. The manual process of which in revit is:
Select Angular from Annotate tab
select the first element
select second
and revit shows the angle between them.
Thanks & Regards
Sanjay Pandey
I didn't knew getting angle between two revit elements would be such a mammoth task.
Thanks & Regards
Sanjay Pandey
boostyourbim
Hi Autodesk,
It looks like in the project environment there is no ability to create an angular dimension via the API. Could you file a request for the development team?
Harry
