angle Parameter in sweep
Hi there,
there is a little question in case of creation sweeps by method.
loading and placing the sweep is not a problem, but i have to rotate the used profile by 90°. I thought using the profilsymbol.angle parameter, but i can't change it by codeside. Is this the wrong way solving this issue?
sweep1 = tmpFamily.NewSweep(true, curves, SP_3, profile, 0, ProfilePlaneLocation.Start);
sweep1.ProfilSymbol.Angle = angle * Mathi.Pi / 180;
Mark
Joe.Ye
Hello, sweep1.ProfilSymbol is read-only property, so you could not change the angle. You can just rotate the Sweep by ElementTransformUtils.Rotate() method. Hope this helps,
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
