AnalyticalModelStick
In new version of Revit API in analytical model is class AnalyticalModelStick. How use this class to set proper aligment. In previous version in analytical model I use method
SetAlignmentMethod(AnalyticalElementSelector.StartOrBase, AnalyticalDirection.Y, AnalyticalAlignmentMethod.Projection)
Thanks in advance
Krzysiek
jeremytammik
Dear Krzysiek,
A sensible place to start would be to search the Internet for "AnalyticalModelStick revit api".
That leads me to
http://thebuildingcoder.typepad.com/blog/2015/04/whats-new-in-the-revit-2016-api.html
http://thebuildingcoder.typepad.com/blog/2015/04/whats-new-in-the-revit-2016-api.html#5.08
I searched for SetAlignmentMethod with little success, except to find that the old obsolete method was removed.
Hmm.
I'll pass your query on to the development team and see what they have to suggest for you.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
I fix problem in this way
AnalyticalModelStick stickModel = (AnalyticalModelStick)targetInstance.GetAnalyticalModel();
and then
stickModel.SetAlignmentMethod(AnalyticalElementSelector.StartOrBase, AnalyticalAlignmentMethod.Projection);
and it looks direction is take from instance and don't need to be set now.
jeremytammik
Dear Krzysiek,
Thank you very much for letting us know!
I accordingly marked your solution as the solution 🙂
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Thank you 🙂
