An interesting bug of the standard function ;)
Hello!
In my code I use Revit api function "Distance". Like this:
C.Distance(p)
I got an interesting error. If C - is arc and p - is center of this arc, this function doesn't work.
I got error:
Distancethrew an exception of type 'Autodesk.Revit.Exceptions.InvalidOperationException' Double {Autodesk.Revit.Exceptions.InvalidOperationException}
RPTHOMAS108
Would be the same limitations as described within Curve.Project method exceptions I assume (generic solutions).
