An Example for using MultiReferenceAnnotation?
Message 1 of 10
Hello
Is it possible to get an example to create a Multi-rebar annotations, I search on the Revit SDK and found I have to use the MultiReferenceAnnotation class.
But I can't build an example with the current information.
For creating A normal Rebar Tag I'm using the Autodesk.Revit.Creation.Document.Create.NewTag method
I notice the independent tag has a property named MultiReferenceAnnotationId.
I'm using VS2012 c#, Revit 2014 and Windows 8 64bits
Replies (9)
Message 2 of 10
jeremytammik
Dear miguel.alanis,
Please note the MultiReferenceAnnotation.Create method taking a MultiReferenceAnnotationOptions argument.
The minimum options are probably the type and ElementsToDimension.
Here is an excerpt from an internal test suite I received from the development team:
  var view = GetElement<View>(124186);
  var rebarList = GetElements<Element>(RevitDoc, new[] { 280427 }).ToList();
  Assert.IsTrue(rebarList.Count > 0, "There are no rebars in the document!");
  IList<ElementId> elementIds = new List<ElementId>();
  foreach (Element rebar in rebarList)
    elementIds.Add(rebar.Id);
  MultiReferenceAnnotationType type = GetElement<MultiReferenceAnnotationType>(RevitDoc, 260544);
  Assert.IsNotNull(type, "the MultiReferenceAnnotationType does not exist!");
  MultiReferenceAnnotationOptions options = new MultiReferenceAnnotationOptions(type);
  options.TagHeadPosition = new XYZ(0, 100, 0);
  options.DimensionLineOrigin = new XYZ(5, 5, 1);
  options.DimensionLineDirection = new XYZ(0, 1, 0);
  options.DimensionPlaneNormal = view.ViewDirection;
  options.SetElementsToDimension(elementIds);
  using (Transaction tran = new Transaction(RevitDoc, "Create_Rebar_Vertical"))
    tran.Start();
    var mra = MultiReferenceAnnotation.Create(RevitDoc, view.Id, options);
    var dimension = GetElement<Dimension>(RevitDoc, mra.DimensionId);
    tran.Commit();
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 10
Dear Jeremy,
Thanks for the answer
Best Regards
Miguel Angel Alanis
Message 4 of 10
jeremytammik
Dear Miguel Angel,
Thank you for your response. I put it on The Building Coder as well to ensure it is easily found:
http://thebuildingcoder.typepad.com/blog/2013/09/multireferenceannotation-example.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 10
Maciej_Darmochwal
I would like to refresh the topic because i cant found any information about option that i could manage orientation (vertical,horizontal) created tags. Is that possible?
Message 6 of 10
lukasz_koc1
if you haven't found the solution yet you can use this :
annotation = MultiReferenceAnnotation.Create(doc, view.Id, annotation_opt)
tag = doc.GetElement(annotation.TagId)
tag.TagOrientation = TagOrientation.Horizontal
I have one question too. Do you know why in the dimension line i have 2 additional references? The bars are bended but in this view they are shown as points( bend in above the section)
2020-04-09 10_29_35-Autodesk Revit 2019.2 - [Bellona testowy_lukasz.koc@wsp.com - Section_ Section 1.png
Message 7 of 10
jeremytammik
Dear Łukasz,
Thank you for your answer, and also for the new question, which I already answered (as far as I am able to) in the comment on The Building Coder:
https://thebuildingcoder.typepad.com/blog/2013/09/multireferenceannotation-example.html#comment-4867...
If you can determine the geometric location of the feature that each reference is associated with, you should be able to use that information to tell the two apart.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 10
jamess166
As it is done to locate the location of the reinforcements to place the dimension.
I'm trying to understand how geometry works in views. I imagine it could work like this.
Options opp = new Options();
            opp.View = RevitTools.doc.ActiveView;
            GeometryElement geoEl = r.get_Geometry(opp);
            BoundingBoxXYZ box = geoEl.GetBoundingBox();
            //Creo lista de elementos
            List<ElementId> listIds = new List<ElementId>();
            listIds.Add(r.Id);
            //Opciones de Multirebar
            MultiReferenceAnnotationOptions opt =
                new MultiReferenceAnnotationOptions(ViewTools.MultiRebar);
            opt.TagHasLeader = false;
            //Ubicaciones
            opt.TagHeadPosition = ?????;
            opt.DimensionLineOrigin = ?????;
            opt.DimensionLineDirection = ?????;
            opt.DimensionPlaneNormal = RevitTools.doc.ActiveView.ViewDirection;
            opt.SetElementsToDimension(listIds);
            MultiReferenceAnnotation.Create(RevitTools.doc, r.Id, opt);
The intention is that it works for any view and any type of presentation.
Message 9 of 10
pedro_abril
Hello, I have a question with the above code.
How do you get a reference to the individual rebars elements within the rebar?
I have reviewed the messages indicated in the links and the API documentation (2022), but I have not found a way.
In the example code I need to know how to get the part with question marks:
public void RebarAnnotation(Document doc, View view, Rebar rebar){
  //  I already have it
  MultiReferenceAnnotationType type = getAnnoType();
  MultiReferenceAnnotationOptions options = getAnnoOptions(type);
  // I need the part with question marks
  foreach (Element rbr in ???) {
    elementIds.Add(rbr.Id);
  using (Transaction tran = new Transaction(doc)) {
    tran.Start("Rebar Annotation");
    MultiReferenceAnnotation.Create(doc, view.Id, options);
    tran.Commit();
Thank you.
(I have edited to correct some errors in the code)
Message 10 of 10
pedro_abril
Thanks to the help of the development team (thanks to Naveen Kumar T) I have solved the previous question.
I leave the solution for future reference in case it helps someone else:
  // With the reference to the set of bars it is enough.
    tran.Commit();
With the reference to the set of bars it is enough, it is not necessary to identify each individual bar.
