Always show the same button on SplitButton
rikard.nilsson
rikard.nilsson
I have created some buttons and placed them inside a SplitButton.
The problem I have is that I want have the same effect that Revit has in thier buttons.
I want to show the same button always even if I choose one below in a SplitButton.
When I choose a button below in mySplitButton that always will be the new default that shows on the SplitButton.
Regards
Rikard
jeremytammik
Dear Rikard,
Thank you for your nice query.
Yes. That is in fact very easy to achieve.
I show you how in my HoloLens Escape Path Waypoint JSON Exporter:
https://thebuildingcoder.typepad.com/blog/2016/09/hololens-escape-path-waypoint-json-exporter.html
The add-in displays the following ribbon panel:
ExportWaypointsJson ribbon panelExportWaypointsJson ribbon panel
You can either click the main button, which is always displayed at the top as the current option, to trigger the main command, or drop down the rest of the stacked button contents to display the option button:
ExportWaypointsJson main command and settings buttonsExportWaypointsJson main command and settings buttons
You can grab the entire Visual Studio solution and project from the ExportWaypointsJson GitHub repository:
https://github.com/jeremytammik/ExportWaypointsJson
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
rikard.nilsson
This was my simple solution..
splitButtonClearLoads.IsSynchronizedWithCurrentItem = false;
