addparameter without forgetypeid
ivo.lafeber
Message 1 of 8
ivo.lafeber
Dear all,
I get a message about the ParameterType which is deprecated in Revit 2022 and may be removed in later versions.
in the addparameter function there is still the option which accepts ParameterType, but there is no option which accepts a ForgeTypeId, does anybody know why that is ?
Replies (7)
Message 2 of 8
Omar_Amen
Dear @ivo.lafeber,
you can use   addparameter function with ForgeTypeId arg only if you are using RevitAPI.dll of Revit 2022,
but I can notice that u have the 6 overloads of the function which means you can use ForgeTypeId !
Message 3 of 8
ivo.lafeber
Not only the ParameterType has to be changed to ForgeTypeId, but also the BuiltInParameterGroup 🙂
Message 4 of 8
ivo.lafeber
In a family a parameter can be added to a group called "other", in the api it is the BuiltInParameterGroup. Invalid.
Group Invalid cannot be found in GroupTypeId, also Other cannot be found, which ForgeTypeId is the "Other" group?
the error which occurs
Message 5 of 8
Omar_Amen
Are you getting the same error with different BuiltInParameterGroups or it's be only with the .INVALID one ?
Message 6 of 8
ivo.lafeber
for now only with the INVALID one, I've not (jet) tested all the groups.
Message 7 of 8
imustafa_adel
Hi Ivo,
You can use the following code
C#:
doc.FamilyManager.AddParameter("paraName",new ForgeTypeId(),SpecTypeId.Number,true)
python
doc.FamilyManager.AddParameter("paraName",ForgeTypeId(),SpecTypeId.Number,True)
Message 8 of 8
a.bejenaru
Did you try to use in C#
new ForgeTypeId(string.Empty)
 This stands for the Other group
