Adding properties to dockable pane
Kevin.Bell
Advisor Advisor
Kevin.Bell
I've a routine I created for Revit which opens certain views - this uses Win Forms a modeless dialog.
I've decided to update this to a dockable pane, and so I'm in the process of moving it to WPF (and learning WPF!).
Originally, when using a Form, I passed several variables to it, I did this by creating some properties in the Form class, i.e.
        public List<ElementId> getAllSheets_IDs
            get;
            set;
When the External Command ran I created the form with
var myForm = new Form1();
And I could access the property with myForm.getAllSheets_IDs - this worked well.
Now moving to WPF, I have to register the dockable pane in the App : IExternalApplication class which I understand runs when Revit loads (as the docable form needs to be registered in a zero doc state).
This means that the instance of my pane is created in App : IExternalApplication class and I cannot access it from the class Command : IExternalCommand hence I cannot access any properties of it.
Is there a way I can pass data to the pane?
I hope my explanation above make sense, I'm a bit of a noob at this!
Cheers.
RPTHOMAS108
1) Create XAML page with code behind that implements IDockablePaneProvider
2) Create a new item of (1) non-static and assign it to a public static variable in your class that registers the pane (IExternalApplication)
3) Pass the non-static variable as an argument to Application.RegisterDockablePane
4) Access the static variable of your pane to update it from IExternalCommand class
This is the order I found works for me. However it would seem logical to pass the static variable directly into Application.RegisterDockablePane. Probably I tried this and perhaps it didn't work but I don't see why it wouldn't.
Kevin.Bell
Hi RPTHOMAS108, thanks for your reply.
OK, I've created a WPF form, which is XAML, the .XAML.CS code behnd it impliments IDockablePaneProvider with:
   public partial class NewBrowserPane : UserControl, IDockablePaneProvider
        public void SetupDockablePane(DockablePaneProviderData data)
            data.FrameworkElement = this as FrameworkElement;
            data.InitialState.DockPosition = DockPosition.Tabbed;
            data.InitialState.TabBehind = Autodesk.Revit.UI.DockablePanes.BuiltInDockablePanes.ElementView;
        public NewBrowserPane()
            InitializeComponent();
OK, I believe I've done this in IExternalApplication with, I've created a public static variable - myPane, when I create the panelId I then assign it to myPane
    class App : IExternalApplication
        public static DockablePaneId myPane
            get;
            set;
        public Result OnStartup(UIControlledApplication a)
            //Register dockable pane
            NewBrowserPane page1 = new NewBrowserPane();
            DockablePaneId paneId = new DockablePaneId(new Guid("9d7ed357-534f-4d87-afc4-8e784e3b119e"));
            myPane = paneId;
            a.RegisterDockablePane(paneId, "Test", (IDockablePaneProvider)page1);
            return Result.Succeeded;
I'm stuck on this bit, I believe I should change
a.RegisterDockablePane(paneId, "New Browser", (IDockablePaneProvider)page1);
to
a.RegisterDockablePane(paneId, "New Browser", (IDockablePaneProvider)page1, myPane)
But I can't access the definition of RegisterDockablePane to add the myPane arguement.
Am I following your instructions correctly?
Cheers,
RPTHOMAS108
There are a couple of things wrong with your implementation as far as I can see:
  1. You should be using a WPF Page not a UserControl for the pane content
  2. DockablePaneId should be provided as a class level static variable
  3. Should try casting Pane to IDockablePaneProvider when passing into RegisterDockablePane
For comparison I've created a project with a basic implementation for dockable pane this has a separate IExternalCommand  (External Tools dropdown on Add-ins tab) which will update the pane with the time. Dockable panes would usually be used in conjunction with idling event to update them and ExternalEvent to take instructions from them.
Kevin.Bell
Thanks for your response, I'll review your code.
One point about userControl vs WPF Page, when I click 'Add' and 'New Item' in Visual Studio I only get the option to add a userControl, WPF Page is not listed.
Though I see on the code that you sent, when I click Add New Item, WPF Page is listed. It appears that something in my solution is preventing Visual Studio from giving the option of adding a WPF Page?
RPTHOMAS108
Sounds like you started with the wrong template.
If you pick a .Net Framework class library it assumes you want to use Window.Forms. Now it is slightly more complicated with the addition of .Net Core and .Net Standard.
Historically I always created a WPF class library by starting a WPF Application project type and switching the Output type to Class Library then deleting  the files associated with an application i.e. App.xaml and App.config.
Once you have the WPF project started in such a way you then save it as a template.
Kevin.Bell
Oh, OK.
I use the Revit addin template by The Building Coder: https://thebuildingcoder.typepad.com/blog/2018/09/revit-2019-visual-studio-net-add-in-wizards.html
Thats obvioudly set up for Windows Forms as you say... I'll have to create a new one.
Cheers.
