Adding Project Parameters
Yoshiyuki_Miyauchi
Yoshiyuki_Miyauchi
I want to use the Revit API to add project parameters by referencing information in the shared parameter file.
Which API would help? I would be glad to know.
Please click the Accept Solution button if my reply answers your question.
こちらの投稿は役に立ちましたか?良ければ「いいね」お願い致します!
こちらの投稿があなたの問題解決に寄与した場合、「解決策として承認」ボタンのクリックへのご協力をお願い致します。
Yoshiyuki Miyauchi / 宮内よしゆき
openBIM Architect
ONESTRUCTION Inc. Co-Founder & CTO
buildingSMART Japan IFC利用支援小委員会 委員長
bSI BIM Professional Certification | BSI BIM Project Information PRACTITIONER | BSI BIM Asset Information PRACTITIONER
Civil User Group認定インストラクター
[email protected] | TEL:050-3528-8052
Twitter|LinkdIn
Mohamed_Arshad
こんにちは@Yoshiyuki_Miyauchi さん
Kindly follow below steps to add project parameter using Revit API.
1. Open SharedParameterFile
2. Get Group from SharedParameter File
3. Get Parameter
4. Filter Categories
5. Create Type/ Instance Binding
6. Bind parameter to project
Reference Code
//Revit Document Access
            Application app = commandData.Application.Application;
            UIApplication uiApp = commandData.Application;
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            Document doc = uiDoc.Document;
            //SharedParameter File Path
            string path = @"C:\Users\XXXXX\Desktop\TextShared.txt";
            //Open SharedParameter File
            DefinitionFile defFile = app.OpenSharedParameterFile();
            ExternalDefinition parameter = null;
            //Get Group
            foreach (DefinitionGroup group in defFile.Groups)
                if (group.Name == "Demo")
                    Definitions extDefinitions = group.Definitions;
                    //Get Parameter
                    foreach (ExternalDefinition definition in extDefinitions)
                        if (definition.Name == "Demo Parameter")
                            parameter = definition;
            //Filter Categories
            Categories cat = doc.Settings.Categories;
            CategorySet set = new CategorySet();
            foreach (Category category in cat)
                if (category.Name == "Walls")
                    set.Insert(category);
            using (Transaction insert = new Transaction(doc, "add parameter"))
                insert.Start();
                //Create Type Binding
                Binding type = app.Create.NewTypeBinding(set);
                //Bind Type Parameter
                BindingMap map = uiDoc.Document.ParameterBindings;
                map.Insert(parameter, type, BuiltInParameterGroup.PG_DATA);
                insert.Commit();
Reference Links
https://spiderinnet.typepad.com/blog/2011/05/parameter-of-revit-api-31-create-project-parameter.html
Hope this Will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Yoshiyuki_Miyauchi
@Mohamed_Arshad san
Thank you!
That was very helpful.
openBIM Architect
Twitter|LinkdIn
