Adding fields to a schedule
I cant find out how to add a filed to a schedule.
I try to create a schedule and if I use ScheduleFieldType.Instance Revit derives many different fields. Can I choose these fields?
Regards, Alexander
I believe you can use the ViewSchedule.Definition.AddField(ScheduleFieldType fieldType, ElementId parameterId) method to add a new field populated with a desired parameter once you know its ElementId which you can get from the ParameterSet of a FamilySymbol, FamilyInstance or similar element.
Thank you, I will try.
My solution is:
ElementId mark = new ElementId(BuiltInParameter.ALL_MODEL_MARK);
if (schedulableField.ParameterId == mark)
ScheduleField field = schedule.Definition.AddField(schedulableField );
