Adding couplings on pipe.
The below code is splitting the pipe and adding the coupling perfectly, if the line is straight.
Offset is going to negative side, and the pipe diameter is always showing as 200m in the Revit, if i check in the application the pipe diameter is same as the original pipe.
Please can anyone suggest me, how to work if the pipe is having any angles or the pipe is vertical.
Thank you very much in advance.
// code
FilteredElementCollector collector = new FilteredElementCollector(doc);
collector.OfClass(typeof(PipeType));
PipeType pipeType = collector.FirstElement() as PipeType;
Selection sel = uidoc.Selection;
foreach (Element e in sel.Elements)
Pipe c = e as Pipe;
if (null != c)
pipes.Add(c);
if (2 == pipes.Count)
break;
tx.Start("split pipe");
Curve c1 = (pipes[0].Location as LocationCurve).Curve;// selecting one pipe and taking its location.
XYZ p00 = c1.GetEndPoint(0);
XYZ p01 = c1.GetEndPoint(1);
// finding thte length of the selected pipe.
double len = pipes[0].get_Parameter(BuiltInParameter.CURVE_ELEM_LENGTH).AsDouble();
len = len / 2; //dividing the length.
// creatin first pipe
XYZ q0 = p00;
XYZ q1 = p01 - len * XYZ.BasisX;
Pipe pipe = null;
if (null != pipeType)
pipe = doc.Create.NewPipe(q0, q1, pipeType);
XYZ q2 = p01;
XYZ q3 = p01 - (len - 1) * XYZ.BasisX;
Pipe pipe1 = null;
pipe1 = doc.Create.NewPipe(q2, q3, pipeType);
Connector pipe2_start = null;
Connector pipe2_end = null;
double dist = double.MaxValue;
foreach (Connector c in pipe.ConnectorManager.Connectors)
XYZ p = c.Origin;
double d = p.DistanceTo(q1);
if (d < dist)
dist = d;
pipe2_start = c;
break;
foreach (Connector conn in pipe1.ConnectorManager.Connectors)
if (conn.Origin.IsAlmostEqualTo(q3))
pipe2_end = conn;
FamilyInstance takeoff = doc.Create.NewUnionFitting(pipe2_start, pipe2_end);
DeleteElement(doc, pipes[0]);
tx.Commit();
Aaron.Lu
Dear Anusha, is it duplicated with this? http://forums.autodesk.com/t5/revit-api/adding-couplings-to-pipe/m-p/5564601#U5564601
Aaron Lu
Developer Technical Services
Autodesk Developer Network
