Adding a shared Parameter for all the elements in a active view.
Hello!
My goal is to add a shared parameter into the revit model that is shared by all the elements that are in te active view.
Here is my code and my mistake is in the INSTANCEBINDING. Anyone have any idea? Lot of thanks.
public void CreateSampleSharedParameters(Document doc, UIApplication uiapp, Application app)
//Cargamos el fichero
        string originalFile = app.SharedParametersFilename;
        string tempFile = @"C:\Users\Usuario\Desktop\Manu García Romero\Práctica Empresa                         TeamBimCivil\**********\para_comp.txt";
//EMPIEZA LA TRANSACCION AQUI
        using (Transaction t = new Transaction(doc))
              t.Start("Crear Parametro Compartido");
              app.SharedParametersFilename = tempFile;
              DefinitionFile sharedParameterFile = app.OpenSharedParameterFile();
              DefinitionGroups myGroups = sharedParameterFile.Groups;
              DefinitionGroup myGroup = myGroups.Create("ZONAS");
              ExternalDefinitionCreationOptions option = new ExternalDefinitionCreationOptions("ubicacion",         ParameterType.Text);
              Definition myDefinition_ubicacion = myGroup.Definitions.Create(option);
              CategorySet myCategories = uiapp.Application.Create.NewCategorySet();
              FilteredElementCollector collector = new FilteredElementCollector(doc, doc.ActiveView.Id);
              var categories = collector.ToElements().Select(x => x.Category).Distinct(new CategoryComparer()).ToList(); .
              foreach (Category cat in categories)
                          myCategories.Insert(cat);
                          InstanceBinding instanceBinding = uiapp.Application.Create.NewInstanceBinding(myCategories);
                   doc.ParameterBindings.Insert(myDefinition_ubicacion, instanceBinding, BuiltInParameterGroup.PG_TEXT);
                 t.commit();
  • API
lukaskohout
Looking at your code, in the last foreach loop you add categories to the category set. I would recommend to get the binding out of the loop.
In your solution you were binding the categories more than once.
Does this helps?
Hitting Accepted Answer is a Community Contribution from me as well as from you.
vkelani
Use bindinMap.Insert(myDefinition_ubicacion, instanceBinding, BuiltInParameterGroup.PG_TEXT); instead of doc.bindingparameter...
also close foreach loop after adding category to Mycategories.
cheers!
Vish K.
