Adding a parameter through code
I have this code
        public void CreateParameter(ExternalCommandData commandData) {
        UIApplication uiapp = commandData.Application;
        UIDocument uidoc = uiapp.ActiveUIDocument;
        Document doc = uidoc.Document;
        FamilyManager fam = doc.FamilyManager;
        var param = fam.AddParameter("Size", BuiltInParameterGroup.PG_STRUCTURAL, ParameterType.Length, true);
        fam.Set(param, 0.2);
Although I can't seen to run it in the Macro Manager --> http://i.imgur.com/1iaApXy.png
I've also tried running it as an Add-Ins External Tools and this message pops up --> http://i.imgur.com/ZIKpC8i.png
I'm new to Revit API so I'm not sure what I need to do to fix this. Any help would be great.
keith_white
You need to separate the parameter creation and the parameter value update into two transactions.
First create the parameter in a transaction and commit it.
Then update the parameter in a transaction and commit it.
Keith White
Principal Solution Architect, Autodesk Consulting
