Add or remove sheet prefix
62BJW
62BJW
New to Revit API. Looking for guidance on how to go about adding or removing the first character of sheet numbers. Any assistance is appreciated.
62BJW
Hmmm... Was hoping this was an easy question. Guess not?
so-chong
I have found this discussion on the forum.
https://forums.autodesk.com/t5/revit-api-forum/viewsheet-number/m-p/6262684
Would this be useful to you? I hope so.
Further, you should explore the String Class to know which Methods you are going to use for your own need.
62BJW
Thanks for the reply but that link is a link to this post.
so-chong
Oeps, sorry my mistake!
I have edited the link.
Hope this helps
62BJW
Thanks you sir. I will check it out.
JimJia
Thanks for your sharing!Heart
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
